slight miss at idle
Old Mar 21, 2010 | 06:00 PM
nuztome's Avatar
slight miss at idle
anyone else getting this. '83 280 w/141000. fresh tune-up with all the
goodies, including fuel filter. cant figure it out. HELP!
Old Mar 21, 2010 | 06:26 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
Hows the distributor? Any play in it?
Old Apr 5, 2010 | 02:44 PM
Switchtr3's Avatar
mine runs the exact same way. My dash says 141, lord knows how many more miles are actually on it. Full tune up, valve adjustment, fuel filter, intake/ exhaust manifold gasket, just reset my timing back to about 12btdc which was at about 19 (yikes!) and set my idle back to about 800rpm right where it should be. I've replaced many of the vacuum lines. I've thought of just about everything it still idles kind of rough. I'm gonna do a compression test, i may have bent a valve or something, and I know i overheated it a couple of times when i had my coolant leak.
If I were you I would start by checking for vacuum leaks, check your timing and idle speed
hchase17
May 2, 2009 11:03 PM
Zed59
Jul 25, 2008 11:12 AM
jmmorriso
Sep 11, 2006 07:27 AM
OlderThanMe
Jan 28, 2005 11:50 PM
Lithium
Nov 1, 2004 10:40 AM
