Sensor Light Coming On
Old Nov 10, 2003 | 06:34 PM
Lazerus's Avatar
The sensor light in my 82 NA 2+2 just came on and I was wondering if there was an easy way (aka I'm not letting the damn dealer anywhere near my car) to check and see what sensor is having problems. Thanks.
-Matt
Old Nov 11, 2003 | 09:15 AM
You press the button below the light and it flashes which system(s) is at fault. I assume that's what sensor light you're talking about.
Old Nov 11, 2003 | 10:57 AM
Lazerus's Avatar
I don't think there is a button there but I will check when I go downstairs (living on the 14th floor definately has it's disadvantages). The light is in the upper left hand corner of the instrument cluster with the speedo and tach. Thanks though, I will check it out.
Old Nov 12, 2003 | 08:40 AM
No, we're talking about different lights. The light I'm talking about is the square display in the lower center of the cluster between the tachometer and speedometer.
The light your talking about should light up with which system it is warning about. Instead of just calling it a sensor, tell me which light it is. Brake? I forgot.... I haven't had my Z around in a while.
Old Nov 12, 2003 | 09:27 PM
Lazerus's Avatar
It's a little orange light right right above the fuel light that just says "SENSOR" it came on the other day and I haven't been able to find any information on how to see what code it is showing. I'm used to GM where you just jump two terminals and count the blinking light.
If nothing else I may have to take it into the dealership (bastards). Thanks for the help.
Old Nov 12, 2003 | 10:33 PM
lifegrddude's Avatar
Externally Wastegated
It's the O2 sensor light. I forgot which wires it is, but you're supposed to disconnect them cause all it is, is a light telling you to have it checked. It was a factory thing that came on at about 30K miles and the dealer then disconnects it. Nothing to worry about though. I believe the wires were green... (too bad there are a million green wires!) but I forgot the location of them. It's been way too long since I messed with them.
John 82ZXT
Old Nov 12, 2003 | 11:42 PM
Lazerus's Avatar
Alright, I guess I can justg pull the guage cluster and disconnect it from there, thanks.
-Matt
Old Nov 13, 2003 | 08:38 AM
Ok, I guess mine must already be disconnected! I've never noticed that light there before.
Lupe
Apr 13, 2011 12:31 PM
Turbo86
Jan 15, 2007 03:45 PM
DSR300zx
May 21, 2006 01:04 AM
z_girl96
17
Sep 22, 2003 11:19 AM
1320
Dec 16, 2001 05:47 PM
