Rb25det swap mounts.
Old Jun 22, 2011 | 05:24 PM
Teflon's Avatar
Does anyone have the site that you can buy them at? I have seen some people list the company that makes them...but never a site. Thanks
Old Jun 22, 2011 | 07:07 PM
Did you maybe try googling the name of that company (of which you haven't mentioned... ) ?
Also... first google result for "280zx rb25":
http://forums.hybridz.org/index.php/...62-280zx-rb25/
"The RB bolted straight into the existing engine mounts. There was just a little tab on the mount that was square and the rb had a round hole so just drilled it a bit bigger. The engine sits low enouth for the bonnet to close, apparently on a 280z you need to lower it for it to fit but not so on the zx the standard sump does hit the cross member as the member in the zx is a bit further back than in the skylines so all we did was cut around the cercumfrance of the sump and turn it 180 degrees and welded it back on again. the block actually has a blank hole to take the dipstck at the back of the block into the sump insterad of the front which was handy.. The driveshaft splines are all the same. the radiator hoses are all in the right sides. You do however need to use a bit of each gearbox cross member tto combine them to get the gearbox to bolt up. aparently a r30 lsd is a good upgrade and bolts up. we havent tried to put the r32 r200 on it yet. the loomas are prety easy to work out as nissan use a two piece loom so you keep most of the old loom and use the new one from the skyline purly for the engine. All up was pretty cheap. "
Old Jun 22, 2011 | 08:33 PM
Teflon's Avatar
Why does that sound so simple?
Old Jun 22, 2011 | 09:49 PM
BlueKitsune's Avatar
Intrawebz Wizard
That does sound amazingly simple.
Old Jun 22, 2011 | 10:09 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
I can say firsthand that the Rb20 bolted right up. Not sure about the Rb25 transmission, but the Rb20 trans needs the automatic trans mount from the 280zx.
That is from my exp. tho, easy swap since it poofs right in
Old Jun 23, 2011 | 03:24 AM
Teflon's Avatar
Well I found the Rb25 and trans for 1200 so I think I'm going to try it out. I'll document the progress.
wtfchickenz
May 8, 2012 01:07 PM
laynemoore
Mar 31, 2012 05:20 AM
MGounaris
Aug 25, 2011 02:41 PM
devilz72
Aug 18, 2011 02:49 PM
PowerhungryBill
May 6, 2007 06:34 PM
