Rapid Ticking on startup
Old Dec 5, 2008 | 03:03 PM
  #26
Niku-Sama's Avatar
eff good grammar
i never went straight ATF on the motor but majority ATF, probally had a quart and a half in there of clean oil.
i've tried royal purple in other cars, pretty much an expencive synthetic to me so i didnt stick with it
Old Dec 5, 2008 | 03:05 PM
  #27
Niku-Sama's Avatar
eff good grammar
Originally Posted by Ratfink
I have seen worse buildup. Looks like some burnt oil in there, but no sludge from what I can see in the pictures. Hard to tell though.
This is my original engine no rebuild, and old oil after flushing with Seafoam. Again, like the ATF, I wouldn't run it long.
what head is this and whats that bar running the legenth of it.
i dont see it in duos pic and i dont have that on mine
Old Dec 5, 2008 | 03:09 PM
  #28
entropy31's Avatar
The Cake Is A Lie!
Originally Posted by thxone
I can't really say don't use ATF in the engine...I know it's not meant to be in there but it does seem to be a multitasker...hell I use it in place of fork oil on my bike...T-5 manual trannys use it...this list goes on and on. I'd say give it a shot, you never know. I'd pull the lifters though, rebuild them and then soak them in oil before they went back in the car.
it's also what to use on a z32 for the power steering. power steering fluid kills the pump! go figure.
Old Dec 5, 2008 | 04:00 PM
  #29
duowing's Avatar
NisTuner
Z31 also uses ATF for the power steering and that's probably why mine leaks as someone had used regular power steering fluid as far as I can tell.
Old Dec 5, 2008 | 04:25 PM
  #30
Ratfink's Avatar
Hoov for Pres!
This is what adjustable rockers look like, instead of the hydraulic ones.
It that bar running across the cam towers is an oil spray tube. It has little holes on the side facing the cam that would squirt oil on each lobe of the cam. Old school.
That is an E88 head.
The cam that was put in the car when I got it was aftermarket, and drilled for oil. So the spray head was not needed. I removed it, and plugged the oles in the cam towers that feed it to maintain better oil pressure in my engine. The tube itself was broken and causing too much pressure to be lost.
I have an older 260Z, and they were a bit different.
Old Dec 5, 2008 | 06:34 PM
  #31
yeah its an oil bar. its useless lol.
Old Dec 6, 2008 | 12:39 AM
  #32
hermultra's Avatar
if your gonna do the T/F in the motor.. I would go with with reg. motor oil for one more oil change.. to make sure you get all the T/ F out before you go with the expensive syn/ oil.....food for thought
Old Dec 6, 2008 | 11:56 AM
  #33
duowing's Avatar
NisTuner
actually that's a good thought. I didn't really think of that.
Old Dec 8, 2008 | 11:50 PM
  #34
duowing's Avatar
NisTuner
Well on the topic of the hydraulic lifters I started reading at HybridZ some more and I came across a big argument saying that the P90 with the solid lifters makes more power than the P90a and what not. It got me wondering, Nismopick if you check this, didn't you switch to a solid P90? If so did you notice more power, but at the same time maybe it's negligible. Since there were issues with your motor to begin with? Or are you still breaking it in?
Kevdogg
Aug 19, 2014 10:50 AM
batmobile300zx
Mar 17, 2011 07:46 PM
ultimatepoghero
Feb 2, 2010 02:18 PM
KingDatsun1
Mar 23, 2009 03:37 PM
GenHawk
Jan 14, 2005 10:36 AM
