Question????
Old May 6, 2011 | 04:59 PM
Lupe's Avatar
Question????
My Cars RPM Gauge Sometimes Work And Sometimes Doesn't. Im Thinking Its The Connection Behind The cluster Because When I Wiggle The Cluster It Works. My Question Is How Do You Remove The Cluster, Is Removing The Dash Necessary???? Or Is There A better Way????
Old May 6, 2011 | 05:04 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
No, You Can Remove The Cluster Easily, Not Having To Remove The Whole Dash.
You Need To Take Off The Steering Wheel, And Undo The Bolts (Screws) Holding The Cluster In (I Believe There Are Four Screws), And It Should Come Out.
Once You Get The Steering Wheel Off You Should Be Able To Tell Exactly What Needs To Come Off.
Old May 6, 2011 | 05:22 PM
Lupe's Avatar
Thanks Ima Give It A Try.....
Niku-Sama
Other Cars
Jun 24, 2011 10:25 PM
domsgarage
Oct 11, 2010 07:44 PM
