poppy exhaust
basically im saying you need backpressure. its just a minimal amount. you dont want to inproperly design an exhaust to eliminate all backpressur cause it wont happen. so until your a nasa scientis in aerodynamics and fluid dynamics and design the perfect exhaust, there certain basics you stick by and just deal with teh back pressure you have. basically around 6 psi about. because when you do try to eliminate it its done in the wrong fashion and thats where teh torque is lost in the lower RPM's.
i hate to re-open this can of worms, but F1 cars have been effectively adjusting their powerbands by increasing or decreasing the amount of back pressure.
and the valve is there strictly for starting purposes, i tried to start the bike with it open and it wouldnt start.
I also agree that it's practially impossible to creat the perfect exhaust. Theoretically it would have to be a pipe that expanded proportionally to engine speed (RPM). For example, at idle the pipe starts out 2 inches in diameter and stretches out to 3 inches by the time the car reaches redline.
so wh cant we come up with larger primary tubed header with electric valves that adjust with your rpm's then run like 4" exhaust and have basically tuned backpressure. make it so that you have more in low rpms and more in high rpms. sounds like so ferrari stuff. just like the electric valce train the have now...now more cam and stuff....and 100x better than vtech
it does also have to do with back pressure with how much of it you hear... but the root of it is fueling. the engine isn't leaned out enough in deceleration so it's putting too much fuel in for not enough air and therefore have raw fuel into the exhaust. it's for the most part a pretty common thing as you open up the exhaust. i'm running wide open off my 2.5" down pipe from my turbo right now and do not have any popping but then again it's all going through the turbo and doesn't really have any pipe to resonate off of. the muffler/cat help hide this.
hrmm well part of it is my variable timing mod that un intentionally happened, well some one suoer glued the screw head on the distributer adjustment so it fell off when i tried to adjust it, it was too far advanced and it was poppin alot from that.
i keep thinking i am going to get it out but i never do, mabe i should super glue it so it atleast stays in place
i've never had an engine pop when power braking and i do it all the time at work when diagnosing misfire conditions... also when burning my tires with line lock on my caballero before i race it.... so throw that out.
power braking? you mean engine breaking? like allowing the car to slow itself down by leaving it in gear and letting off the throttle? every car will do it. its not pop its more of a gurgle and it can pop. its like this, you let off the throttle so the TPS and AFM and what not arent reading anything but idle readings but the motor is still up in the revs so the mixture is off but its still rotating and getting spark so it will fire in wierd random spots sometimes louder than other times. it happens to EVERY car.
noelawinslow
May 21, 2013 01:17 AM
nismatic707
Jul 16, 2002 12:51 AM
