Overheating Distributor??
Old Jul 31, 2008 | 07:46 AM
NSAgent's Avatar
Ok this is strange. I have a 83 280zxt and I took the car to a local shop that specializes in z cars.
So as Im going up there and the car just dies on me. Hasn't done that in forever and wouldn't start. I had to have it towed to the shop and when it gets there it starts right up no problem.
The guy tells me that my distributor is overheating and needs to be replaced. He also said its a common problem in these turbo cars, but I was sure about that seeing as I have been lurking here and on other forums for awhile and never heard of it.
So what I want to know is, is he telling the truth? Is there a quick fix for this or do I need another distributor? And how hard is it to change myself? Thanks a bunch guys.
Old Jul 31, 2008 | 07:55 AM
Maybe he's talking about the CAS? Or the ignitor?
Ask him what specific part is overheating.... the "distributor" is WAY too general of an answer. Give him this too:
Old Jul 31, 2008 | 08:05 AM
NSAgent's Avatar
Thats why I said it was strange. I dont think I can ask him now because I kind of got mad with the guy and said some things so im out of luck there.
Have you ever heard of any "common" overheating problem though? I have just never heard of that.
Old Jul 31, 2008 | 08:12 AM
It's common to overheat a motor if there's no coolant. As for the common "distributor overheating" issue... sounds like a mechanic trying to get $$$ from any sucker he can. He should have at least told you WHY it's overheating or WHAT specific part. Or maybe he doesn't know what's INSIDE the distributor.
Old Jul 31, 2008 | 09:09 PM
lww's Avatar
lww
Head Muckraker
More likely, he doesn't want you to know what's on the SIDE of the distributor.
Old Jul 31, 2008 | 09:14 PM
luckyZ13's Avatar
my 77 started acting the way yours was about a month ago. put a new pick up coil in the diz and seems to go good now. hasn't died for a week now.
Old Aug 3, 2008 | 12:46 PM
michanic220's Avatar
the only thing i could see over heating would be the pick up coil, as they will do that via shorting out. I've had few melt down before. pretty crazy. the Z distributor has two clips holding it on, at least on mine it does. undo those and it will pull the cap off. other then that to take the whole thing out there should be one or two screws that you loosen to change you're timing. make sure you MARK where the distributor is unless you want to re time you're engine. the only other thing i can think of to make it "overheat" would be friction and i highly doubt its that. not in a distributor.
sounds like a bogus mechanic to me.
Old Aug 3, 2008 | 04:15 PM
280zx2by2's Avatar
Haterade by da gallon!
is your problem just heat or is it shuting off? edit: ( it is shutting off so just keep reading)
if its shutting off replace the icu and pickup coil...if it dosent work then you can just put the ones you bought on the new distributor...
overheating is a major prob with 80's cars and trucks distributors... idk why?
Old Aug 3, 2008 | 04:19 PM
Mhinrichs's Avatar
Mr. Fancy Connectors
correct me if I`m wrong, but ummm doesnt the turbo use a cas instead of a pick up? common overheating on the turbo engine is the igniter, run your car for a while and then stick a finger on the igniter and see how hot it is. if it burns you, that is most likely your problem. Also, just for curiosity sake, pull the distributor cap and see if its got carbon trails, they will look like off colored lighting bolts in the plastic.
Old Aug 3, 2008 | 08:01 PM
You are correct.
Old Aug 4, 2008 | 12:31 AM
nismo619's Avatar
tis possable that the water temp sender is getting old like mine was corroded and just wasnt making a good connection... oil temp senser located right under number 5 spark plug could be faulty or worn out... my 280zxt didnt start acting up really bad until i installed a blaster 2 coil... after it got warmed up it would die.. and wouldnt start for like 20 min... i was geting mad !
Old Aug 4, 2008 | 06:51 AM
I'm pretty sure you meant to say the CHTS (cyl head temp sensor) not oil temp sensor.
Old Aug 4, 2008 | 10:45 AM
duowing's Avatar
NisTuner
As has been mentioned there's a little box on the side of the ignition coil, if you buy a new one it's the box and the bracket for the coil. This is a common problem as it has a tendency when going bad to run until the car warms up then it starts to overheat and causes the car to shut-off. The part is I think around $120, but it's really easy to change. Also if you haven't changed it I'd suggest changing the coil when you change the igniter. You don't have to, but at least this way it's one less thing to worry about.
Old Aug 5, 2008 | 04:03 PM
ASA240z's Avatar
ダットサンマニアック
umm what exactly is the cas and/or igniter?
Old Aug 5, 2008 | 05:43 PM
the thing that generates the spark to be amplified by the coil im guessing.
Old Aug 5, 2008 | 09:20 PM
CAS = Crank Angle Sensor (turbo models only). It's on the timing cover @ the crank pulley on the 81. It's inside the distributor on the 82-83.
Ignitor is the small black unit on the side of the distrib (n/a) or on the side of the coil bracket (turbo) which tells the coil when to spark.
Old Aug 6, 2008 | 01:08 AM
nismo what does the crank angle sensor do actually? i dont see a purpose other then somthing computerized. my buddy has one on his DSM turbo eclipse.
Old Aug 6, 2008 | 02:39 AM
ASA240z's Avatar
ダットサンマニアック
it sends info to the cpu about the engine speed (rpm).
Without it the cpu doesnt really know what the rpm is, in knowing it can adjust.
Old Aug 6, 2008 | 06:09 AM
Well (I'm not saying this sarcastically) the name defines it pretty well. It tells the ecu the crank angle (position of the crank).
A more precise definition: http://en.wikipedia.org/wiki/Crank_sensor
A crank sensor is a component used in an internal combustion engine to monitor the position or rotational speed of the crankshaft. This information is used by engine management systems to control ignition system timing and other engine parameters. Before electronic crank sensors were available, the distributor would have to be manually adjusted to a timing mark on the engine.
The crank sensor can be used in combination with a similar camshaft position sensor to monitor the relationship between the pistons and valves in the engine, which is particularly important in engines with variable valve timing. It is also commonly the primary source for the measurement of engine speed in revolutions per minute.
Crank sensors in engines usually consist of magnets and an inductive coil, or they may be based on magnetically triggered Hall effect semiconductor devices. Common mounting locations include the main crank pulley, the flywheel, and occasionally on the crankshaft itself. This sensor is the most important sensor in modern day engines. When it fails, there is a small chance the engine will start (engine will likely cut out after a few minutes of driving) but it mostly will not start.
Some engines, such as GM's Premium V family, use crank position sensors which read a reluctor ring integral to the harmonic balancer. This is a much more accurate method of determining the position of the crankshaft, and allows the computer to determine within a few degrees the exact position of the crankshaft (and thereby all connected components) at any given time.
Another type of crank sensor is used on bicycles to monitor the position of the crankset, usually for the cadence readout of a cyclocomputer.
Old Aug 6, 2008 | 10:21 AM
ohh, ok i gotcha.
Old Aug 6, 2008 | 10:37 AM
NSAgent's Avatar
Nismo has got to be a god of the zx, thanks a mill. I think the guy may have lied to me about why the car shut off. I've been driving it for a week and a half now and it has not shut off once.
What I paid him for seems to have fixed all my problems so im just going to keep an eye on things until something happens.
Old Aug 6, 2008 | 12:18 PM
zstreet86's Avatar
so what was it?
Old Aug 6, 2008 | 01:19 PM
280zx2by2's Avatar
^^^^ and? it was the....
Old Aug 6, 2008 | 01:37 PM
zstreet86's Avatar
what?.........
Old Aug 6, 2008 | 01:55 PM
zstreet86's Avatar
which is more likely to fail? cas or ignitor?
