No Voltage at my fuel pump
Old Mar 3, 2005 | 02:43 PM
swmoman's Avatar
My old fuel pump was bad... Checked it out and was no good.. Got another pump, but I have no voltage to the pump?
Any ideas? Is there one or two fuel pump relays? If so, where are they located at? Also is there a fuse somewhere I can not find?
Thanks
Swmoman
Old Mar 3, 2005 | 02:58 PM
icice9's Avatar
Super Siver & Black Stud
im not too sure but i belive the fule pump relay is behind your glove box... or it could be under the passenger seat... im not too sure maybe Bleach knows where its at...
Old Mar 3, 2005 | 03:22 PM
280Z4ME's Avatar
Check behind the passanger seat. There is a photo in the Fuel Pump post on the 240,260,280 forum.
Old Mar 3, 2005 | 07:46 PM
theramz's Avatar
I have a present for you...
here we go
I found this in my Chilton book. The fuel pump relay is under the hood on the ps.
Old Mar 7, 2005 | 09:04 PM
3XAZOWNER's Avatar
the fuel pump relay is under the hood, on the passenger side fender behind a flat metal plate. I thought my fuel pump was bad until i pulled the wire up into the trunk and hooked up my working parts car pump. it did not work either. i then pulled the ignition from the parts car, since it acted like someone shut off my ignition switch, but it didnt make the pump whine either. i called my mechanic that i bought the car from and he told me about this relay. if your old pump is still around and the relay is the problem, you may want to test the old pump to make sure it was really bad to begin with. good luck!
Old Mar 8, 2005 | 07:56 AM
The manual says there that it is Fuel Pump Relay #2 that is under the hood...
I do remember a relay clicking behind the glove box (I had the glovebox out) that is related to the fuel pump. This is on my 1982. 82-83 are probably the same. Earlier years may vary.
In that Chilto's picture, one of the relays in the little black box is long. All 82-83 don't have the larger relays like that.
Old Mar 9, 2005 | 09:17 PM
Speed's Avatar
Dude!
Check out KTMrider - Fuel Pump - on the 240-280Z board. More info on Fuel Pump Relays!
Speed
Enjoy the Ride!
pete7956
Sep 25, 2013 07:23 AM
michanic220
Jun 19, 2008 03:13 PM
cdeshane
Jul 23, 2005 09:58 PM
Gr8White
Jul 5, 2005 04:31 PM
swmoman
Mar 7, 2005 07:57 PM
