my 280zx won't hold above 3000rpm
Old Apr 24, 2018 | 09:34 AM
zman62's Avatar
Hi all,
I just picked up a 82 280zx 2+2, auto. It ran fine as I drove it home for over an hour ride. Next day I washed the engine bay. I tried to avoid the distributor, alternator, etc. I idled it for an hour after to let it dry. I took it on the road later that day and power dropped above 2000-3000 RPM. When I park and rev up to 3000 RPM, power drops and bobbing back and fourth. Do you guys have any ideas? I thought it was lack of fuel, but still the same after replaced the fuel filter. Thanks in advance!
Old Apr 24, 2018 | 02:05 PM
Welcome to ZDriver!
And yup... classic mistake. Unplug TPS connector, blow dry, plug back in. Also remove distributor cap and blow dry. Install and drive happy.
Old Apr 25, 2018 | 04:33 AM
zman62's Avatar
Thank you for your add, NismoPick.
I will try what you have suggested. Also, The speedometer was working fine the day I drove it home. At the same time I was encountered the above problem, I noticed the speedometer wasn't working. This must be something non related ? I think the car has cable to the speedo, but does it have a speed sensor that I may wetted? Thanks so much!
Old Apr 27, 2018 | 04:19 AM
zman62's Avatar
Well, It is running great! Thanks to NismoPick! I found out it was a puddle of water in the plug..
What do you drive NismoPick?
Old Apr 27, 2018 | 06:27 PM
Nice. Love the easy fixes.
I have an 81 2+2 that I've done a bit of work to. Turbo swap with lots of goodies.
Attached Thumbnails my 280zx won't hold above 3000rpm-a2-sized.jpg   my 280zx won't hold above 3000rpm-engine-bay-2016-sized.jpg
Old May 1, 2018 | 05:03 AM
zman62's Avatar
That is funny. I just picked up an 82 280zx 2+2. It is in rough shape as far as interior. Engine has 114K. I always wanted one as I had a 280zx coupe a long time ago. I like the look of a 2+2 much better as it is longer. Always a Z fan. I also have a Z31 and a Z33.
I like your engine bay. Hopefully mine can look like that sometime, I think I am done with washing the engine
BillyD Z
Oct 30, 2016 12:32 AM
chef_tickwon
Jun 6, 2003 06:12 PM
300zxBoi
Jun 2, 2003 12:01 PM
Ford Falcon
May 13, 2003 07:00 AM
Skully
May 7, 2002 01:57 PM
