must be blind
in the s130's its up attached to the steering wheel colum. it clips into a little plastic thingy with the signal flasher, its way up there. pull the lower panel out, then the foot warmer vent, and get a flashlight and look way up.
are you just looking for the switch to turn the hazards on? If so it's right on the steering column. A tiny little switch, it took me a while to figure out where it was located. I'm so used to having some sort of big obvious switch. Heck even the older Z cars had an obvious hazard switch.
