Lady in my car is not talking
My local pick and pull have many z. I am just wondering what part should I replace for the lady in my car to talk again. Would any body know please give me some advice? Thanks.
NONE of the warnings work? Have you tried the e-brake warning? Door open? Low fuel?
If none work, you probably need to replace the unit. Search here for previous threads... we've discussed problems & the location of the unit.
She does not say anything at all. Could you tell me what is the unit call? and where is it located? Thanks.
BTW the upgrade of the 300zx turbo ECU is excellent. Do you know why it takes longer to start, but before the swap it start right up?
Plus the Auxiliary Air Valve will no longer need? Because I tried to disconnected and the car did not start up. There are still many vacuum hose that I like to remove but dont know exactly which.
Thanks again.
Thanks again.
https://www.zdriver.com/forums/showt...ighlight=voice
Here... I'll SEARCH for you....
Thank you. I assume the unit from a 300zx would work.
Reconnect it to see if it makes a difference......... Reconnected and it start fine.
Just because you would "like" to remove them, doesn't mean you should.
I was under the impression that the talking lady was only connected to one speaker. She started clicking at me the other day, cause my lights were on with the car off, dunno if thats a good thing, cause I thought it was my fuel pump at first O.o
^^^ Indeed... dash center speaker.
Good points. So Benny, do you have an aftermarket stereo installed? If you turn the headlights on (no key in ignition), and open the drivers door, do you hear a click coming from the black box?
The FSM should show the wiring to and from the talking lady.
Don't know why you would want her in there O.o
http://www.youtube.com/watch?v=gsDxJ...eature=related
My 86 turbo I can hear " lights are on", and something like that.
If I can modify the voice detection, I would of put a sensor detection says " WHO FARTED IN MY CAR".
