Lady in my car is not talking
My local pick and pull have many z. I am just wondering what part should I replace for the lady in my car to talk again. Would any body know please give me some advice? Thanks.
NONE of the warnings work? Have you tried the e-brake warning? Door open? Low fuel?
If none work, you probably need to replace the unit. Search here for previous threads... we've discussed problems & the location of the unit. |
She does not say anything at all. Could you tell me what is the unit call? and where is it located? Thanks.
BTW the upgrade of the 300zx turbo ECU is excellent. Do you know why it takes longer to start, but before the swap it start right up? Plus the Auxiliary Air Valve will no longer need? Because I tried to disconnected and the car did not start up. There are still many vacuum hose that I like to remove but dont know exactly which. Thanks again. |
Originally Posted by benny127
(Post 284883)
(Post 284883)
https://www.zdriver.com/forums/showt...ighlight=voice https://www.zdriver.com/forums/showt...ighlight=voice https://www.zdriver.com/forums/showt...ighlight=voice
(Post 284883)
(Post 284883)
(Post 284892)
Here... I'll SEARCH for you....
https://www.zdriver.com/forums/showt...ighlight=voice https://www.zdriver.com/forums/showt...ighlight=voice https://www.zdriver.com/forums/showt...ighlight=voice Thank you. I assume the unit from a 300zx would work. Reconnect it to see if it makes a difference......... Reconnected and it start fine. Just because you would "like" to remove them, doesn't mean you should. :D |
Bought one did not work, tried second one from another car still no talking. I guess she left for a richer guy. Thanks.
You bought ones from a Z31 or 280zx?
(Post 284931)
Do your interior lights work? Cruise control work?
(Post 284939)
I was under the impression that the talking lady was only connected to one speaker. She started clicking at me the other day, cause my lights were on with the car off, dunno if thats a good thing, cause I thought it was my fuel pump at first O.o
^^^ Indeed... dash center speaker.
Good points. So Benny, do you have an aftermarket stereo installed? If you turn the headlights on (no key in ignition), and open the drivers door, do you hear a click coming from the black box? |
The FSM should show the wiring to and from the talking lady.
Don't know why you would want her in there O.o http://www.youtube.com/watch?v=gsDxJ...eature=related |
(Post 284964)
Good points. So Benny, do you have an aftermarket stereo installed? If you turn the headlights on (no key in ignition), and open the drivers door, do you hear a click coming from the black box? My 86 turbo I can hear " lights are on", and something like that. If I can modify the voice detection, I would of put a sensor detection says " WHO FARTED IN MY CAR". |
I would make mine sound like Jarvis from Ironman.
"Your fuel level is low sir." If I could. Or the generic flight stewardess. Soft calming voice. |
(Post 284971)
ohh man that would rock...
But I agree with Wangan, Jarvis all the way! |
Originally Posted by KHCreason
(Post 285131)
But I agree with Wangan, Jarvis all the way! A systems check shows that your left door is open... Especially in the Paul Bettany voice, no other way |
