L28 turbo head
Old Dec 30, 2003 | 10:11 PM
icice9's Avatar
Super Siver & Black Stud
P90 and the P90A the P90A had hydrolic lifter
Old Jan 1, 2004 | 11:57 AM
TheeZ's Avatar
Coming to understand "Z"
preferred?
which is the preferred head? w/ or w/o the hyrdo lifters? what are the benifits of each?
Old Jan 1, 2004 | 02:52 PM
icice9's Avatar
the hydrolic heads are a lot more quiet then the non but the at very high RPMs they tend to float.. as far as the p90 goes you can still adjust them....
Old Jan 5, 2004 | 12:52 PM
and they did not use the N42 block. Nissan specifically changed to a different casting in 1981. The started the F54 block for the turbo motor and to save on production costs they used that same block with the non-turbo. But yes, they put flat top pistons in the non-turbo for higher compression. The turbo dished pistons have larger rings in them.
Instead of saying they used the non-turbo block in the turbo cars I would say they made a block for the turbo but also used it for the non-turbo.
Old Jan 21, 2004 | 08:16 AM
Swap the motor!
That's the best bet.
WanganDevilZ
Nov 13, 2014 07:15 AM
godjimm
Nov 10, 2012 07:47 AM
juan240z
Mar 13, 2012 10:58 AM
280zExTURBO
Oct 10, 2005 12:27 AM
Timberwolf
Apr 5, 2002 01:59 PM
