Jet Hot Fuel Rail?
Old Nov 1, 2006 | 01:53 PM
tomjohn51's Avatar
Site Supporter!
Jet Hot Fuel Rail?
I am in the process of rebuilding my intake manifold and I plan to get it coated with jet hot. Does it make sense to get the fuel rail coated also?
Old Nov 1, 2006 | 01:58 PM
For looks? Sure.... it won't make any performance difference tho... and if ya count the 4oz of paint added... could technically be considered adding weight
Old Nov 1, 2006 | 02:38 PM
jfairladyz's Avatar
Well I dont know actually. Cooler fuel will lower intake temps and would allow more power to be made. It wouldn't add any power on its own though. It would also add a little more security against detonation due to the lower temps. A hot fuel rail just brings the fuel permaturely closer to its flash point (not a good thing until the spark plug fires).
JetHot isn't the cheapest thing though so it would be a cost vs effectiveness issue. But if you figure it would look good on top of keeping the fuel cooler then it might be worth it. I'd be interested in seeing just how much cooler it would keep the fuel. If our intake manifolds werent right above the exhaust manifold then I'd say it was pointless though.
Old Nov 1, 2006 | 02:42 PM
You saying the paint would actually keep the rail cooler in a hot engine bay? Maybe if there was a cross flow of air... but the way it's setup, I can't see how it would keep it cooler.
Old Nov 1, 2006 | 02:49 PM
jfairladyz's Avatar
Maybe I'm not following here. But when I read JetHot I assumed he was talking about the header coating. Not a paint. The coating actually acts as a heat barrier so it would prevent heat from soaking into the fuel rail. If we're talking a paint then no, I see no advantage. But JetHot is not a paint.
Old Nov 2, 2006 | 02:57 AM
Heat Rave R's Avatar
I think he meant "paint" as in it's a liquid that's applied as a coating to something.
Pez
Feb 9, 2015 04:27 PM
zdrifter91
Jun 11, 2014 11:16 AM
ericeel
May 25, 2014 10:29 PM
83ZXGurl
Jan 22, 2012 03:23 PM
SHADY280
Mar 8, 2006 04:30 PM
