Inner tie rod ends
Old 12-15-2014, 07:42 PM
mikey280zx's Avatar
Inner tie rod ends
I was told by technician I need to renew mine. Has anyone here done this job? I have 79 280ZX manual steering.
mikey280zx is offline
Old 12-16-2014, 12:44 AM
zxguy1986's Avatar
Replaced them on my original '86NA. Techie was a front end alignment pro, lifted the car, grabbed the tire at 9 and 3 oclock and could wobble it. Not supposed to wobble. I took the opportunity to rebuild the whole steering rack, ball joints, bushings, etc. I figured since I wore it out, I should fix it. Included poly bushings. You can check out the parts numbers on your XenonS130 fiche and start with those to find replacements. Otherwise there are a bunch of pretty cheap kits out there that can be adapted to fit, or so they claim. It cost me a little more to do the whole set-up but it saves on tire wear. Getting my original factory Z steering back was worth it. Rock solid straight ahead on any road surface. Car is still knocking my socks off after all these years!
zxguy1986 is offline
Old 12-16-2014, 08:05 PM
mikey280zx's Avatar
Can the inners be done on car or should I remove rack?
Old 12-17-2014, 02:06 AM
zxguy1986's Avatar
On a Z31, you can just do the tie rods. Check your service manual and parts fiche for the S130/280ZX. I bet you can tell that from the diagrams.
99TNA
03-04-2012 07:51 PM
I_B_Don
11-19-2011 12:52 PM
GTH
05-20-2011 05:45 PM
entropy31
07-08-2007 08:01 PM
nka04a
05-09-2006 11:12 PM
Quick Reply: Inner tie rod ends
