I just noticed...what is this, and why is it disconnected?
Old Sep 7, 2007 | 01:52 AM
Heat Rave R's Avatar
So while fiddling around in my engine bay ('82 Turbo), I noticed something that I've looked at a thousand times, but never paid much attention to. Attached to a bolt on the coil bracket plate, there's a little cylindrical thing, about 1" long and as thick as a AA battery. It has one wire coming out of it that goes to a spade-connection on the distributor, next to the main plug. And it has another other wire coming out of it that terminates in a male-bullet connector, but isn't currently connected to anything.
Long ago, I installed a Crane ignition/coil, and I'm assuming I disconnected that little cylinder during the process. But it's been so long, I have no idea what that thing was connected to, or what it did. I tried checking the service manual, but couldn't offhand find out what it is/does. So does anyone what that thing does with the distributor and/or what it's supposed to be connected to?
Old Sep 7, 2007 | 07:11 AM
It's a condensor to reduce RF interference. It connects from the coil harness to the bottom of the distrib housing. It's not needed w/ the 280zxt ecu, but I remember someone saying it does help w/ the Z31 ecu... then again, you aren't using the stock coil anymore...
Old Sep 7, 2007 | 01:50 PM
tickwon's Avatar
Ha ha you know I always wonder about that too...thanks for clearing that up.
Old Sep 7, 2007 | 05:10 PM
So is it basically a noise filter? Should I still hook it up to the coil? I do have an MSD noise filter connected to my Crane already, so would it be redundant you thinK?
masterhufflpuff
Apr 2, 2015 10:28 AM
static.wise
Jan 30, 2015 05:58 PM
mantis992
Jan 20, 2014 10:07 PM
BlueKitsune
Jun 7, 2009 09:12 PM
davidjoe007
Jul 7, 2005 03:14 PM
