Going to SUs!
Old Feb 22, 2010 | 02:25 PM
BlueKitsune's Avatar
Intrawebz Wizard
Going to SUs!
Well I'm just going to drop the EFI for now and I'm wondering if anyone has anything to share about EFI to SUs swap. And if anyone knows a good affordable fuel pump that I can replace the EFI one with. Er and if anyone knows anything I should look out for. with this
Old Feb 22, 2010 | 03:01 PM
280zx2by2's Avatar
Haterade by da gallon!
Edz280zx should have just the answer for you, if he reads this.
Old Feb 22, 2010 | 05:20 PM
mayitin's Avatar
Your car will run better with EFI and will be more economical on gas.
You will have to use a carb fuel pump, you will need the mani folds, the SUs, the lincage, the heat shield to conect the return springs etc etc. Do you have all the parts? if not e mail me I have everything. Mcamps228@aol.com
Old Feb 22, 2010 | 07:23 PM
Intrawebz Wizard
All I'm missing the the stuff for the choke. and an electric fuel pump. Which I actually have one but it doesnt fit the big like 1/2 inch line from the tank.
Er no wait I'm missing the air filter.
Old Feb 22, 2010 | 08:09 PM
Intrawebz Wizard
How hard is it to rebuild SUs? I'm going to do it for peace of mind and the fact idk how long its been sense they got rebuilt.
Old Feb 23, 2010 | 04:39 PM
mayitin's Avatar
About the fuel pump if you have one all you need is to down size the hose. To rebuild the SUs is simple if you know how to work on cars. you can have partial rebuild Black dragon has them or a complete kit Z theraphy has it. get you a good book on SUs and go for it, is not that complicated. If you are an old guy like me, you have worked on carbs, so tuning them is no problem but if you are young get the Z theraphy DVD on how to do every thing.
Old Feb 24, 2010 | 09:42 AM
at-jefft's Avatar
Uber n00b!
Its easy, just get the rebuild kit from Z Therapy. It comes with everything(no other kit I have heard of does) and a video explaining how to rebuild and tune.
Old Feb 24, 2010 | 09:58 AM
Intrawebz Wizard
Their "Complete Tune Up Kit for 2 carbs"? I probably will get it just for the fact it has everything I need. The Checker kits only come with gaskets and the float needles I think.
Old Feb 24, 2010 | 10:05 AM
at-jefft's Avatar
Uber n00b!
Yup, correct. Most of the time its worn needles/seats that are the issue so the big box rebuild kit is pretty useless
Old Feb 24, 2010 | 10:29 AM
Edz280zx's Avatar
This is a relatively straight forward swap, especially since the fuel injection harness is almost entirely seperate from the engine harness. Basically, just act like your putting a carbed v8 in it and you'll be fine.
Old Feb 24, 2010 | 11:31 AM
Intrawebz Wizard
Sweet. I actually started to consider Z Therapy's SS Reman Carb set. Hmm... I hope this comes out running pretty well!
Old Feb 24, 2010 | 02:36 PM
the z therapy kit is the greatist, plus su's hold tune a bit better than webers. they can actually produce good power, and not have bad mileage. tonyd on hybridz loves his su's, i forget the power capabilities, but i was astonished, its comparable to tripples. if you run a good regulator with return system, you can actually leave the stock pump as is.
Old Feb 24, 2010 | 03:56 PM
Intrawebz Wizard
Sweet! I finally worked out all the details or my rebuild too. P90 head, N42 Block with Flattops, SU's and 6-1 header Still trying to decide on the head shave and the overbore...
Old Feb 24, 2010 | 07:11 PM
Edz280zx's Avatar
I recommend an aftermarket ignition also...I used a Crane XR3000 from Blackdragon..get's rid of the pesky dizzy box.
Old Feb 24, 2010 | 07:25 PM
Intrawebz Wizard
??? I'm using a 280ZX dizzy and I dont mind it
Old Feb 24, 2010 | 11:54 PM
Intrawebz Wizard
Ok I have to ask a probably stupid question. What are those red'ish spacers for???
Old Feb 25, 2010 | 07:04 AM
Edz280zx's Avatar
They are vibration and heat insulators...you NEED them.
Old Feb 25, 2010 | 11:12 AM
Intrawebz Wizard
See I told you it was a probable stupid question lol
Old Feb 25, 2010 | 01:12 PM
FubarI33t's Avatar
i once considerd the weber swap, but deceded to stay with EFI, it's what i know. Untill Ed there decided to sell his beloved triple set up. i fell in love with the triple's all over again. but i may never go with them, just depends, i am still secound in line for that motor.
Old Feb 25, 2010 | 04:29 PM
Intrawebz Wizard
If I was near where hes at, I could have bought that engine in a heartbeat. still would if he would ship it lol
Old Feb 26, 2010 | 01:17 AM
FubarI33t's Avatar
i live in MS, so it would be a 1 day there, one day back for it, but so worth it. sadly, i don't think ima get it though oh well. if i don't, on to the SHO motor i got
Old Feb 26, 2010 | 07:05 PM
Intrawebz Wizard
I **** brix today, today I took my entire engine down to the machinest to be cleaned up and get ready for a rebuild, I was talking to him for awhile and I decided to ask about if he knew where I could get an LD28 Crank, then he says that he might actually have one and if he does I can pretty much just have it! So I might start looking into a 3.1L engine!
I don't think my luck is that good tho lol But you never know!
Old Feb 26, 2010 | 07:19 PM
I've got 4 of the 6 pistons you need for the 3.1L. They are from a 92 KA24DE. Unfortunately you'll prolly have to source another set of 4 just to get the 2 more you need.
Old Feb 26, 2010 | 07:53 PM
Intrawebz Wizard
Sweet! Tho. Can you do this mod w/o an overbore? just not hit 3.1L obviously
Old Feb 26, 2010 | 08:10 PM
PurePontiacKid's Avatar
i felld offa mai trike
You'll need custom pistons I'm pretty sure. it'd only be 2.9 without the 89mm bore...
