Fuel Pump Relay Access?
Ok, I've been going back through my harness and resoldering all the connections I made for the Z31 ECU swap, which when I finally soldered the ground connections has made quite a difference. Anyway, is there anyway to get better access to the Fuel Pump Relay? I know you have to take the glovebox out, and I can get my hand in there to unplug it. I have no idea how I connected it in the first place, I know the wires are just twisted together cus I couldn't get a crimper in there. Is there any way I can pull it out more to get a bit more access to make it easier to get at without having to pull the dash?
Glove box & kick panel... those are the only two access points. Other than that it's pull the dash. Or maybe you could just loosen the dash, pull it forward some, and that would give more room?
