fuel injection spray pattern
Old Mar 25, 2010 | 08:53 AM
ITSZX's Avatar
I was having a real rich fuel situation, have done everything suggested and by the book. Still problems. It was suggested that I pull the whole injection system out and turn the motor over and look at the spray pattern of the injectors(cold start injector included). I have not seen the spray pattern before but to me it was not atomizing, more like a stream. So has anyone ever looked at this before, what does the pattern look like? no fuel out of the cold start either.
Old Mar 25, 2010 | 10:17 AM
The cold start has a built in relay. I think it only cranks when the temp sensor says the engine is cold and then only sprays while cranking, not when the engine fires up.
I have never looked at the injectors spraying.
Old Mar 25, 2010 | 06:04 PM
FubarI33t's Avatar
I am also running extremely rich, no cold start. but my temp gauge ain't workin. so i think the ecu thinks the engine is always cold. it fouls out one of the cylinders once the engine is warmed up
Old Mar 26, 2010 | 03:57 PM
The temp gauge runs on a seperate sensor from the ECU IIRC....
MulletMan
Dec 6, 2012 10:14 PM
gflaurie
May 21, 2007 01:21 PM
majajason240
May 11, 2003 05:45 PM
ZMATTDADDY
May 12, 2002 11:19 AM
jeff
Aug 22, 2001 07:26 AM
