Fog in the car
Old May 23, 2003 | 05:43 PM
Skully's Avatar
climate control??
just dont turn the **** to climate control turn it to defogger it should be ok if thats what your talking about.... but im taking mine out just unhooked it and threw it out i dont think it worked anyways....
Old May 25, 2003 | 12:57 PM
lifegrddude's Avatar
Externally Wastegated
It's possible, but I heard it's time consuming. If you run a search in the zcar.com archives in the 70-83 tech forum, you might find what you're looking for. I hate the auto climate, that thing is stupid, it will 90 degrees outside and it won't work. If it's 40 degrees, it'll work.
John 82ZXT
Old May 29, 2003 | 12:22 PM
If your windows fogg up really easy then you might need to just clean them really good with windex a couple times. Even if it doesn't kick in at the right time, the defrost position should at least blow air out. If that doesn't work then you have other problems. Maybe a bad fan motor or a blown fuse on the bottom of the fan motor.
