Electrical problem in brake circuit.
Old Jun 17, 2011 | 08:14 PM
Teflon's Avatar
Hey, new to the forums and Z car ownership! I have a 79 280zx N/t and I have a small problem that is draining my battery. Whenever I press my brake pedal all of my lights dim ,the radio shuts off, and the dash lights come on. Thinking it might be a bad ground so I'm going to tackle it with a volt meter tomorrow but just checking on here to see if anyone else has had a similar problem and found a simple fix.
Old Jun 17, 2011 | 09:46 PM
Welcome to ZDriver!
I suggest getting your alternator checked.
Old Jun 18, 2011 | 01:38 PM
Teflon's Avatar
Tested just fine. More info though, the voltage is at a constant 14 when off the brake pedal. Jumps around when I press it. Hope it's not a short... I'm not electrically inclined.
Old Jun 18, 2011 | 02:25 PM
noboosts130's Avatar
Lurker
I had the same problem on my 79. The ground cables coming off the battery were bad.
Old Jun 18, 2011 | 03:44 PM
Teflon's Avatar
Ground cables are fine replaced em anyway for good measure but same problem.
Old Jun 18, 2011 | 04:04 PM
Skully's Avatar
Well since its with the brakes on only, check the back lighting for bad grounds/shorts?
Old Jun 18, 2011 | 04:24 PM
Teflon's Avatar
Yeah I thought that too, I had a tail light out and cracked plastic on the 79 rear lights so I swapped to fully working 82 tail lights and the problem didn't go away. I'm thinking maybe one of the wires rubbed the insulation off and is grounding out but I don't think the tail lights would work if that was the case.
Old Jun 20, 2011 | 11:02 AM
Teflon's Avatar
Yeah still no luck. Now the car is dying out after it starts (with a jump) I hate electrical bugs.
Old Jun 20, 2011 | 11:23 AM
Maybe your battery is toast (since you are jumping it)?
Old Jun 21, 2011 | 08:49 PM
Teflon's Avatar
4 Day old battery. Just went through the entire car and sanded and re grounded every connection. Still doing it... Bad switch maybe?
Old Jun 21, 2011 | 09:16 PM
Why were you jumping it w/ a new battery in it?
Old Jun 22, 2011 | 04:41 AM
Teflon's Avatar
It died out, wouldn't start up. A couple days ago I got the battery test done after the car wouldn't start and it tested bad. So I went and got a new battery. Worked fine for about 3 days and then died again. I doubt it's the problem though since the car had the same problems before and after the new battery.
BackHouseZ
Oct 2, 2011 12:02 PM
our964
Sep 29, 2010 03:13 PM
dragon
Feb 11, 2008 12:41 PM
bardabe
Jan 18, 2005 10:25 PM
rigez
Jan 8, 2002 08:12 PM
