ECU messing up?
Old Oct 21, 2011 | 01:48 AM
zordietrying's Avatar
ECU messing up?
For the last few months my 82 280zxt willl run good one weekend and not good the next. Not really run bad, just doesn't have the power that it should. I have check, replace, or rebuild AFM, TPS, CHTS, spark plug wires, cap rotor, fuel presure, vacum lines and I'm sure theres more. Sometimes when I think I fixed it, the next weekend it runs crappy again. While searching online, on a nissan site, someone said that there Z does this once in a while and they have to unplug the battery, then unplug ECU, then plug them back in. So I tried it and it seemed to have worked, well for now at least.
Does any one else have a problem like this?
Is the problem really the ECU or is there another problem causing the ECU ot mess up?
Any insite on this would be great.
Old Oct 21, 2011 | 05:16 AM
sparkycon's Avatar
You might also check the ignition module which is attached to the distributer. That sounds what mine was doing in the early stages of the module going bad...
Old Oct 21, 2011 | 09:36 PM
Where did you find a new ignition module? I can't find one. It's unavailable. I'm thinking of switching to the HEI module. But I have heard good and bad things about it.
Old Oct 21, 2011 | 11:06 PM
evandubya's Avatar
Primer Grey FTW!
Ebay usually has them.
Old Oct 22, 2011 | 08:43 AM
rogerz's Avatar
Grumpy & Helpful
check on your battery system. Z's don't like low voltage causes all sorts of gremlins.
Old Oct 22, 2011 | 04:59 PM
HEI module is an easy swap and usually el cheapo. I'm running one on my turbo.
Old Oct 22, 2011 | 05:49 PM
sparkycon's Avatar
I got it on eBay for about $40! Car runs like a top now!
Old Oct 22, 2011 | 08:48 PM
How does the HEI run at higher RPMs?
She's got new battery, cables, and alternator.
Old Oct 22, 2011 | 09:01 PM
On ebay $160-$180, dam.
Old Oct 23, 2011 | 10:26 PM
sparkycon's Avatar
http://www.ebay.com:80/itm/LX554-Ign...sories&vxp=mtr
Here is the one I got works for 82-83... About 30 bucks!
Old Oct 23, 2011 | 10:33 PM
I see HEI modules run perfectly fine at 7-8k RPM all the time. For about $100 you can get an MSD module with a built in rev limiter and a bunch of other features.
Old Oct 24, 2011 | 08:25 PM
Thats for a non turbo.
Old Oct 24, 2011 | 08:30 PM
I have a Mallery 6l with a built in rev limiter. But you still have to wire that through the stock module, inless I have it hooked up wrong.
Old Oct 24, 2011 | 08:43 PM
You're talking about an ignition box, I'm talking about an MSD HEI module. It wires into a magnetic crank trigger and to the coil. It replaces your ignition module.
Old Oct 25, 2011 | 01:01 PM
Do you have the Malory hooked up already? If so did you try running it without the Malory?
Old Oct 27, 2011 | 04:35 AM
I do have the Mallory hooked up, but I havn't tried to run with out it. And I will have to check out that MSD HEI module.
Old Oct 27, 2011 | 05:30 PM
Try running without it and can you hook the Malory up bypassing the ignitor?
Old Oct 28, 2011 | 11:59 PM
I tried to bypass the ignitor when I hooked up the Mallory and it was a no go. I dout the mallorys bad. Has anyone use a MSD HEI on their Z? How did you like it? Can you recommed a Mallory one?
Old Oct 29, 2011 | 09:57 AM
sparkycon's Avatar
Sorry I'm a dope. I didn't read that part...
Old Oct 29, 2011 | 10:24 AM
Yup I'm running one on my test mule right now. Works just fine. There is a write up on it but they are missing hooking up the blue wire to the negative side of the coil on the stock harness. If you keep it hooked up to the driver transistor the HEI will not work. If you leave it disconnected your tach won't work.
Old Oct 30, 2011 | 05:35 AM
So you are saying that either your tach works or that HEI? Got a link for that write up? And maybe a part number. And my tach works off and on, and jumps around ever sense I part on the Mallory. Got any ideas about that? I was thinking I need a higher amp alternator.
raythenegr0
May 28, 2008 04:45 PM
DatsunKid
Jan 3, 2008 05:05 PM
WildmaN
Nov 18, 2006 12:30 PM
Ravin
Jan 11, 2006 02:14 PM
