Dizzy ball bearings
Dizzy ball bearings
Hmmn. replaced rotor and cap last night and saw a ball bearing in the bottom of the distributor. After searching the web, found out what it is.
atlanticz/tech tips.....
My question is, will this fail and leave me stranded? I plan on trying to take it apart and rebuild or look for a new breaker plate assembly sometime in the next week or so but I still drive it to work. Not enough $$ to buy a new dizzy this year. Maybe next year.
Has anyone rebuilt one of these? Can someone tell me the difficulty level?
If the triangular plastic piece is not broken, can I just reseat the ball bearings?
And yes, I have both the FSM and Haynes manual (POS).
Thanks
Thanks
I tried re-seating and lubing the bearings in a dizzy I had. It went together but the vaccuum advance still was sticky. That's all those bearings ride on...
I replaced it with a used dizzy. Move the rotor with your hand and then let it 'snap' back into place. If it has good return spring action then its a good distributor. 1977-84 Nissan/Datsun 810/Maxima L24 works as well as most any 280Z or 280ZX distributor. non-turbo only.
KevinH
Sep 6, 2005 05:48 PM
