Ditching EGR on 82 ZX...will it hurt anything?
Old May 9, 2007 | 12:16 PM
Matt K's Avatar
I'm considering getting rid of the EGR on my 82 ZX in oder to use a certain header I came across, would there be any driveability issues?
Old May 9, 2007 | 12:31 PM
thxone's Avatar
Only if you plan to try an pass emissions. It should not mess with the cars drivability though. Many aftermarket intake manifolds for V8's have EGR block off plates...it 99% an emissions thing. You will be fine my friend
Old May 9, 2007 | 01:55 PM
Matt K's Avatar
Thanks! That's what I was thinking, but I'm still new to the S130's!
Old May 9, 2007 | 04:42 PM
duowing's Avatar
NisTuner
From what I've seen from Bleach and others, they've thrown out the EGR and still passed emissions. The only way it sounds like you might fail is if there's an under-hood check. I think it was snow who mentioned that the only disadvantage of not having the EGR was that you'd have to let your car to warm up, but after reading up on how the EGR system works. Vacuum isn't even allowed to the EGR until the car is at operating temp.
Old May 9, 2007 | 05:07 PM
^^^ yep, except for the warm up part... you mean for emissions testing it needs to be warm? You should always do an emissions test w/ the car at operating temp.
Old May 9, 2007 | 05:24 PM
duowing's Avatar
NisTuner
For the warm-up part, I meant I had asked if there were any disadvantages to eliminating EGR and snow said the only disadvantage was that you have to let the car warm up first. So I read up on it, and found there's pretty much no disadvantage other than emissions, although it sounds like for the stock Z there's really no advantage.
Old May 9, 2007 | 05:55 PM
you should, and thats mostly with colder weather conditions. i cnat remember why. but i remember your supposed to.
Old May 9, 2007 | 08:38 PM
Matt K's Avatar
I bought a Motorsport Jet-Hot header off of ebay for a 79-80, called Motorsport to see if it would fit my 82...the EGR is different & won't connect to their kit, so I'm considering ditching it or swapping an EGR from a 79-80 model.
Old May 9, 2007 | 08:43 PM
duowing's Avatar
NisTuner
Just from what I was reading in the Haynes guide it tells about the EGR for 81-82 year models, I'm pretty sure it didn't change for 83, but anyway it says that there is a Thermal Vacuum Valve(TVV) placed in between the Throttle Body and the EGR valve, and it is supposed to be closed until the Engine Coolant hits 131*F or normal operating temp so the EGR won't function and lean out the rich mixture that a car normally has when it starts.
I would just say ditch the EGR or if you can, while you're pulling everything apart to install your header, see if you can grab an N-42 intake I believe it was. It had no EGR valve, gives your intake a bit of a cleaner look, and gives you just a bit more room, maybe not so neccesary for an N/A, but it's definitely more helpful on the Turbo models as there's more room to get to the Turbo.
Old May 10, 2007 | 06:54 AM
i dont have an egr. and we have the exact smog testing as california. i just used a 3/8" npt plug for the bottom and get a bolt for the header hole. i even left my egr valve in place with no block off for inspection incase they look. it stays closed anyhoo.
Old May 30, 2007 | 11:21 AM
ZYAL8R's Avatar
Yeah, I have a '79 N/A and I disconnected my egr when I put in the MSA header. I had to cut the pipe that goes to the header and plug it up. As far as driving goes, it's great. We don't have emissions tests in Texas, so I'm cool. What else can we take off if we don't need to pass emissions?
SHADY280
Nov 2, 2008 10:43 AM
Matt K
Jan 19, 2008 02:24 PM
Fast240Z
Nov 7, 2005 08:49 PM
pete8717
Oct 27, 2005 05:11 AM
refurbit
Jul 29, 2005 01:30 PM
