Clutch problems
Old Feb 24, 2008 | 09:37 PM
cockerstar's Avatar
Question Clutch problems
Hey guys,
When I went out to my project car about a week ago I started her up, pushed in the clutch, and when I went to put her into gear I got a surprise. It just grided...
So I pulled my foot off the pedal and to my surprise it stayed on the floor!
The car had been sitting in the garage for about a month without being started in winter weather (down to about 10-15 degrees outside) and hasn't been driven since thanksgiving day.
What could be wrong besides a shot slave cylinder?
Hopefully it just requires a quick bleed, but I'm kind of skeptical because it ran fine when I parked it a few months ago.
Old Feb 24, 2008 | 10:28 PM
Check fluid level... bleed master... and wa-la!
Old Feb 24, 2008 | 11:08 PM
either master cylinder or slave cylinder is shot. or you have a leak in the line. try adding fluid and bleeding the system if it happens again i say just replace both of what i mentioned.
Old Jun 6, 2008 | 05:21 PM
Agent_Whyte's Avatar
Hey i am in the same boat but the fluid levels are good as far as i can tell.
Old Jun 6, 2008 | 09:37 PM
duckyz's Avatar
Bleed out the master, then bleed out the slave (cylinders).
87_silverz31
Apr 7, 2012 10:56 AM
zxer91
Aug 7, 2011 12:09 AM
FairladyZ84
Feb 21, 2006 10:33 AM
Darius
Oct 14, 2005 09:04 PM
hndah8r
Aug 15, 2003 09:24 AM
