clutch problem
Old Mar 8, 2004 | 06:13 PM
duckyz's Avatar
You could try bleeding out the clutch resivoir (like bleeding your brakes, I'm told) and refill as necessary. It also might be the linkage binding a little. If you go under the car and look at the tranny housing up close to the motor, you'll see the linkage. It should be fairly easy to pull apart. Smear liberally with grease......then take a test run! (I like the test runs....)
Last case scenario (that I could think of) would be that the springs in the pressure plate are worn out. This means.....new clutch.
If this doesn't help.......ask Ice.
Yardjass
Apr 8, 2012 07:58 AM
snwbrderphat540
28
Apr 29, 2008 11:43 AM
anyrug
Mar 11, 2007 08:05 PM
Fourtunata
Jul 30, 2006 04:31 PM
MarkieMark
Sep 13, 2005 05:25 PM
