Clutch Master Cylinder
Old 12-19-2012, 05:41 PM
burble_boy's Avatar
Ok guys I have a clutch master cylinder ready to be installed. Problem is when I try to bench bleed it my bleeder screw doesn't stay in the threads. Is there a special type of bleeder screw you guys use? I bought a bunch and one is the correct thread size, but doesn't work. Any ideas?
burble_boy is offline
Old 12-19-2012, 05:53 PM
Grumpy & Helpful
rogerz's Avatar
just install it. forget the bench bleed bs. keep the reservoir full and pump the pedal with your arm with the slave bleeder open. got a friend helps. or buy a vac kit from harbor freight.
rogerz is offline
awilkie
02-22-2016 03:06 PM
GTH
04-12-2013 01:56 PM
JSimpson
FS: 300ZX (90-96)
07-25-2011 10:59 PM
zstudent
01-08-2009 09:09 PM
Carl's Z
01-17-2005 04:04 PM
Quick Reply: Clutch Master Cylinder
