camber plates
Old Mar 11, 2011 | 08:25 AM
ITSZX's Avatar
camber plates
Anyone have a good suggestions for the best front camber plates? Also, the best shock tower brace?
Old Mar 11, 2011 | 09:34 AM
Camber plates - not a lot of choices but an excellent product....
...and while you're ordering from there you should get their TC Rods and bump steer spacers....
Cusco makes a good set of shock tower braces. Top End Performance also carries a three point brace. There isn't anything super techical about a strut tower brace - just physically tying the braces together so as long as it doesn't fold in half most people are looking for something that looks good. A three point is going to give you more bracing though so I'd tend more along those lines...
Old Mar 11, 2011 | 12:32 PM
Don't forget that those camber plates require coilover suspension up front. Get their $199 weld-together kit.
Techno Toy Tuning!
Old Mar 11, 2011 | 12:59 PM
Lol - I guess what I should have said is call Tech Toy up and order all the 280ZX stuff he has
Old Mar 11, 2011 | 01:05 PM
i have the camber plates. good stuff, you have to cut the top of the strut tower to clearance the adjusters, but its real easy. i made mine work fine with no coilovers. i think there is a different part needed with coilovers tho. there is info on his site if i remember
Old Mar 11, 2011 | 01:39 PM
Did you slot your rear a-arm mounts for camber adjust on the rear?
Old Mar 13, 2011 | 02:54 PM
no i havent made it that far yet, ive been slowly collecting parts for the racecar. i was thinking heim ends welded where the bushings are or making modified arm mounts.
Old Mar 14, 2011 | 03:19 PM
I'd like to move the whole mount back a bit as well so the tire is more centered in the wheel well. The tire will rub towards the front of the wheel well before it rubs anywhere else (like the top, etc)
Treacy
Mar 12, 2014 04:51 AM
madhatter
Jul 19, 2004 03:06 PM
calvinD
Jun 1, 2004 05:59 PM
racer5gogo
Mar 10, 2004 04:07 PM
tyco1983
Jan 24, 2002 10:31 PM
