a/c blower
Old Aug 1, 2008 | 07:56 PM
hermultra's Avatar
a/c blower
why would my blower not be blowing hard... it seems to be blowing about half of what should be....just the other day I noticed when I got on the gas,it would stop blowing, untill I backed off , then it would start blowing again, but not strong, still half what it should........& the motor is not making that much noise.
1 what's the most likley cause?? vacume/door not adjusted??
2 where is the best place to start looking ??
thanks hermultra
Old Aug 1, 2008 | 08:31 PM
duckyz's Avatar
Sometimes mine will stop under heavy acceleration. But, I've disconnected my a/c, so I don't run it all that much. Just for heat in the winter.
Old Aug 2, 2008 | 08:59 AM
On the n/a the vacuum to open the vent ports comes direct from the intake manifold.... at full throttle, there is little vacuum in the intake & thus the vent ports won't open & will fall back to default floor vents.
On the turbo the vacuum comes from a vacuum pump up by the inspection light. It makes a very distinct pumping noise when it's going.
Can you hear it when you turn on the vent / a/c?
Also... do you have the ACC (auto climate control) or manual control?
davidjoe007
Jun 29, 2021 04:45 PM
NSFR
Mar 31, 2013 12:50 PM
J-cubZ
Feb 14, 2011 01:16 PM
SHADY280
Jan 18, 2008 08:20 AM
del
Jan 7, 2002 05:59 PM
