blinker?
Old Apr 23, 2005 | 10:07 PM
81 Black L28E's Avatar
blinker?
Ok my blinkers stoped working ..i still have flashers/HAZARDS but know blinkers i checked the fuses and all of them were still golden.... what should i check next ?????is there a relay some where...
Old Apr 24, 2005 | 03:44 AM
It sounds like your flasher for the turn signals is out. It should be below the dash on the driver's side. It id either burnt out or a wire got disconnected. Hope this helps
Old Apr 24, 2005 | 10:52 AM
thanks player it does............. going out to check it right now
Old Apr 24, 2005 | 03:48 PM
Ok i couldnt find anything not hooked up under there so most likely the box went out......... there are two or three boxs under ther .......witch one is it
Old Apr 24, 2005 | 07:20 PM
Ooh I'm not exactly sure. It is going to be a metal round thing. When you tap it, sounds hollow kind of light a light bulb. It should be hooked close to the firewall. I can't quite remember. If you still can't find it. I will go look at my '81 for you!
Old Apr 24, 2005 | 11:30 PM
i will look i the moring drove around all day with out it and didnt get pulled over
Old Apr 24, 2005 | 11:37 PM
i will look in the moring drove around all day with out it and didnt get pulled over
Old Apr 25, 2005 | 03:03 PM
Dorifto's Avatar
Wow ... that's wicked. You posted twice in 7 minutes, the same message.
That's Golden Grahms.
oneadvent
May 28, 2012 07:17 PM
Pipsqueak
May 24, 2012 02:15 AM
falcon125
Apr 13, 2009 02:15 PM
Whitesmoke
Jun 24, 2006 03:41 PM
lightspeed
Aug 25, 2004 04:33 PM
