BCDD Block off??
BCDD Block off??
I have determined to have a bad BCDD. I am now reading where you can just bypass it by blocking it off. Has anybody done this procedure ? Did it mess with your EGR? IF this works I fiqure I could do it until I find one. The dealer weants $300 for a new one.
Thanks in Advance.
Black83NT
Thanks in Advance.
Black83NT
BCDD Removal ?
Nis~
Upon futher hunting apparently this can be done with 80's and older when introducing mods ect .. I did read one post where one guy says he removed it blocked it off with gasket material and put it back on and has no issues .. Hmm ,,I find that hard to believe..I cant seem to find that link now..but I googled 280zx BCDD removal and a page of stuff came up..I am of the status if its not needed it wouldnt be on the car.. I would rather get another one but this little part is much harder to locate than MAss Flows & Idle control valves ect..
^^^ It's technically called a BOOST Controlled Deceleration Device.
You yourself said it was likely his idle problem: https://www.zdriver.com/forums/showt...868#post306868
EDIT... FricFrac beat me to it.
AV240Z
Apr 28, 2003 05:04 PM
