Bad ZX Moon?
Old Sep 28, 2004 | 10:08 PM
duckyz's Avatar
Bad ZX Moon?
What's up guyz (and galz... )? Seems like everyone is having the same problem at the same time!!!!!! Someone HAS to have a guideline for us....
Ugh......I'm tired of bangin' my head against a wall!!!!!
Old Sep 28, 2004 | 11:34 PM
Las VegaZ's Avatar
What problem are we having?
Old Sep 29, 2004 | 09:50 AM
lights not working, engine shutting off after warming up.... ??? is that it? No turbo charger! hehe...
Old Sep 29, 2004 | 11:57 AM
duckyz's Avatar
Na....seems like everyones car is running sluggish, stopped running (like mine), is having electrical issues.........seemed like we were doing so good for a while.
Old Sep 29, 2004 | 12:20 PM
fenderbender02's Avatar
yeah with mine I have to hold the gas pedal to the floor to keep it running. If I let off it dies. I can't figure this one out yet. I am going to replace the spark plugs and maybe the fuel pressure regulator abd see if that helps. Maybe drain the tank and start fresh
Old Sep 29, 2004 | 12:47 PM
duckyz's Avatar
That's what I did....11 months ago. It was running just fine and then it just started losing power until it didn't even turn over. Starter works good, and I'm getting spark......I dunno. I'm lost.
Old Sep 29, 2004 | 02:22 PM
The engine turning over refers to it cranking. If the starter works and the engine is not seized then it will turn over. If it won't fire up, then thats something different.
Old Sep 29, 2004 | 04:57 PM
duckyz's Avatar
Sorry.....it won't fire up.
Old Sep 29, 2004 | 10:12 PM
Las VegaZ's Avatar
And mine is still blown up
Old Sep 30, 2004 | 07:26 AM
rifleman502's Avatar
my clutch went out.....
Old Sep 30, 2004 | 07:49 AM
my transmission went out.... a long time ago
Old Sep 30, 2004 | 10:01 AM
280gty's Avatar
IMPORTANT...
Uh, In case anyone is considering doing anything crazy... I was just joking...there's no such thing as Bad Karma or Vampires...
Old Sep 30, 2004 | 11:51 AM
Heat Rave R's Avatar
Heh, I'm picking up my 280ZX today and now after hearing about all you guys, I'm gettin' scared! ^^
Old Sep 30, 2004 | 03:04 PM
EZDUZIT's Avatar
East Coast Style
Originally Posted by 280gty
This is odd...
Yesterday, I had to jumpstart my 280ZX to get it started and overnight I had to jumpstart it again this morning...all the lights came on when I opened the door but the car wouldn't start. When I jumped it, the car started & then suddenly died again...and I jumped it again..revved it a few times and everything was fine...now an hour later, all the lights/radio seems to work but it needs another jump to start the engine...damn, I gotta have the mechanic check it out...seems like bad karma here...
I believe that in order to end the bad karma, we have to find the one who started it...I think I traced it to doogle749 (unable to call it quits) next is futureZowner (not enough voltage)... If it was a vampire, I believe a stake in the heart would end the problem...
Dude that happend to my Pathfinder about a year ago. You need to replace your battery. What happens is the battery shorts out inside, it will still produce voltage but will carry no amp load.No amp load means no cranking, It will mess with you bad but this has happend to me Twice.
Old Oct 2, 2004 | 04:08 PM
Zskyline79's Avatar
Same problem
MY z used to do that until i changed out the battery cables that hook up to the battery. oh and problems hmmm let s see, first the car would die out after being on for a bit, then brake line blew, no there seems to be a water leak in the engine bay but thats minor. My major issue right now is the heater since the heater core valve on my z is already given out so prolly gonna have to pack her up for the winter.
Old Oct 2, 2004 | 05:57 PM
Talking
Well maybe the moon is starting to set I cranked mine up tonight and she ran pretty good a little rough but at least I could drive it. Well time to reinstall the dash and my new white face gauges!
Old Oct 4, 2004 | 12:55 PM
Man, I think my Z's doing the same thing too! I'm planning to change out the fat positive and negative cables, but did you also change out the two smaller cables that attach to the positive terminal? They go to some small black plastic box near the battery (what is that?)
Old Oct 4, 2004 | 11:54 PM
Las VegaZ's Avatar
Mine is back together finally. She still looks like an abonded vehicle. I am afraid to take her any where near the junk yard as they might take her back in. I tried to start her up tonight, no start . But since it was late will try again tommorow. Hopefully the bad moon has set.
Old Oct 5, 2004 | 04:27 AM
I took mine out for a spin yesterday and she drove like a dream. I was rather amazed.
Old Oct 6, 2004 | 10:42 PM
evildky's Avatar
if the car is only dieing after it's warm and you still have spark, vave someone click the key on and off and see if the fuel pump is kicking on, this happened to a fellow club member recently, they pump would kick but not run and it was hot to the touch, replaced the pump no more trouble, if however you have no spark when this happens check the module on the side of the dist (assuming it's and n/a car) a bit trickier with a turbo dist
Carl's Z
Aug 12, 2006 02:46 PM
