'83 Zx turbo: Hot idle problem
Old Dec 13, 2011 | 10:59 AM
mjz's Avatar
mjz
I have an '83 ZXT that idle's normally with the ACC vacuum line capped.
If I re-connect the vacuum line to the ACC valve, the car almost stalls.
Any thoughts on the problem? The ACC valve seems fine (works normally).
When the engine is cold, the idle is good even if the vacuum line is connected, only as the engine warms does the problem materialize.
Old Dec 14, 2011 | 08:46 AM
Welcome to ZDriver!
Are you connecting the vacuum line to the intake manifold or to the EGR / AAC actuator pump under the AFM?
Old Dec 14, 2011 | 10:14 AM
mjz's Avatar
mjz
Welcome to ZDriver!
The vacuum line is factory connection. The AAC line connects to the actuator pump (V.C.M) near the AFM. Right now it is disconnected and unplugged. I don't believe there is anything wrong with the AAC since the car idles just fine not connected. If I connect the vacuum line, the idle drops to almost stall (i.e. the AAC is actuating and letting in too much air).
Old Dec 14, 2011 | 10:32 AM
IIRC, the AAC default is open. If you are hooking up vacuum, it is closing it, limiting the air flow. The same problem occurs when you remove the AAC all together and use a block off plate.
Double check that all the vacuum lines are run correctly, and that the EGR / AAC lines haven't been switched. Either way, if it runs fine disconnected, you can just leave it be.
Old Dec 14, 2011 | 02:00 PM
mjz's Avatar
mjz
What good is it - if it's not needed? (AAC blocked off).
dillenrocha
Aug 21, 2013 02:29 PM
Kremlar
Sep 15, 2011 05:20 AM
jooom
Aug 6, 2005 04:35 PM
mm107
Aug 3, 2005 06:43 PM
deckart
Nov 27, 2002 04:20 AM
