83 280zxt running rough
Old Sep 27, 2007 | 09:26 AM
mikep's Avatar
I just purchased an 83 280zxt and the car is running pretty rough.The engine is missing and i assume that would have to due with incorrect timing.Also, the car will drive but, not accelerate very well.When i push on the gas.The car has no power.It seems like the engine dosen't want to rev.The owner didn't have clue what was wrong with car.Any ideas on what the problem may be?
Old Sep 27, 2007 | 09:37 AM
Welcome to ZDriver!
Check all the basics... timing, vacuum leaks, a/f ratio, spark splugs, cap and rotor, sensor connections (especially the TPS, AFM, and CHTS), and ecu plugs.
Old Sep 27, 2007 | 10:17 AM
the engine is missing? well, you need an engine in the car first. Then check your timing. 20 deg BTDC should do.
Old Sep 27, 2007 | 10:37 AM
mikep's Avatar
Yes, the engine is in the car.By missing, i meant it will seem to run fine,then run sluggish.I did put new plugs, dizzy cap,and rotor.
Old Sep 27, 2007 | 12:06 PM
duowing's Avatar
NisTuner
I actually read it the same way bleach did, then I realized that you meant it had a miss.
entropy31's Avatar
The Cake Is A Lie!
bleach stole my joke.
Old Sep 27, 2007 | 12:39 PM
I sure did. You need to stop sending me your good jokes before you post them.
The Z is all up ins was in my sig a long freakin time ago dude... long time ago
UT3 FTW!
Old Sep 27, 2007 | 12:57 PM
mikep's Avatar
Sorry, i shouldv'e worded my post a little better.Anyway, cleaned all connectors, unplugged the ecu plugs 8 times.Checked the afm and the flapper is opening.The car does run better then before.I think the timing is off.
I am new at this guys so, please don't give me a hard time.The search feature is helping me out big time.
Old Sep 27, 2007 | 10:08 PM
luvturbo74's Avatar
Check my thread from I think last december. Lotta good advice was dished out to me.
Old Sep 28, 2007 | 07:33 AM
PooFlinginMonke's Avatar
Take off the kick panel cover by your left foot.
When driving the car, grab the wiring bundle and wiggle it a bit while on the gas.
Most likely, the car will accelerate like it should temporarily.
steady88
Apr 23, 2013 08:29 AM
Hamer007
Jun 10, 2011 02:35 PM
tehweej
22
Jul 9, 2007 09:52 PM
91Zman
15
Oct 24, 2005 07:08 PM
chrisc0623
Dec 14, 2003 09:20 PM
