83 280zx problems please help
Old Mar 3, 2011 | 08:22 PM
speedrules86's Avatar
i have an 83 280zx turbo and i replaced the distributor cap and rotor. I didnt get the cap on correctly. the rotor crashed into the cap so i put a new cap and rotor on it. now when i start it. it starts and idles but i cant rev over 1000 rpm. Drove great before i replaced it, now it doesnt. Any ideas? Please share....
Old Mar 3, 2011 | 09:01 PM
Welcome to ZDriver!
I bet the spark plug wire firing order has been mixed up. Did you double check? It's 1-5-3-6-2-4
Or the TPS is wet / unplugged.
Old Mar 4, 2011 | 07:21 AM
wolfalp1592's Avatar
Check spark at each plug, also check that cap is on firm, I just recently replaced mine and the cap was not sitting down firm.
Old Mar 4, 2011 | 08:22 AM
Thanks
we checked the plugs and they were correct. The TPS is also dry and plugged. Any other ideas?
Welcome to ZDriver!
Old Mar 4, 2011 | 11:44 AM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
When it 'crashed' did the distributor twist/move at all or did parts and chunks go flying? Maybe timing is off a bit?
Old Mar 4, 2011 | 01:10 PM
Well
is there a way to check the timing. It could be off. thats the only possibility we have so far.
I put the plug wires on according to this post and the chiltons book. And it doesnt start. there is a one stamped on top of the cap is that the first cylinder?
Old Mar 4, 2011 | 01:13 PM
More!
it cut a grove on the inside of the cap on one side. it broke off two contacts for the plug wires on the inside. but the distributor didnt move the dot on the block and the dot on the distributor housing are still lined up. it doesnt look like it moved at all.
Old Mar 5, 2011 | 05:30 PM
damn it to hell!!!!!!
well how the plug wires were on the dizzy when i got the car it ran good we crashed the cap and rotor put new one on it would start and idle but bog baddly if i try to rev over 1000rpm so i checked in the chilton book my brother said the wires are *** backward and put them on acc to the book and now it wont start at all and i cant but them back because i didnt have them marked. as i cranked it a loud pop came from under the hood and it smelled like electronics so im taking it to a mechanic that i know that has done alot of old datsun and nissan z cars but thats 100 an hour and i already have almost 5000 in the car.
please anyone help is the order the same for the turbo l28 as the l28 n/a?
Old Mar 6, 2011 | 07:57 PM
In case you missed my prior post...
It's 1-5-3-6-2-4
EDIT... I even have a Haynes manual scan pre-uploaded (FYI... you should burn that Chilton's and buy a Haynes, or download the FSM).
Old Mar 16, 2011 | 06:02 PM
Wont RUn please help
i have an 83 280zx and it wont run. It is currently in the shop and they cant figure it out either. I have replaced the starter and distributor. The fuel pump works and the fuel filter is new. Cant check the timing because it wont run long enough. When you crank it over, it dies. Any ideas on what it could be? I am out of options and would love to get it fixed ASAP!
Old Mar 16, 2011 | 06:15 PM
still more problems
got the spark plugs correct. still having problesm. It is currently in the shop and they cant figure it out either. I have replaced the starter and distributor. The fuel pump works and the fuel filter is new. Cant check the timing because it wont run long enough. When you crank it over, it dies. Any ideas on what it could be? I am out of options and would love to get it fixed ASAP!
Old Mar 16, 2011 | 07:03 PM
A motor needs 3 things to start:
-proper air
-proper fuel
-proper spark
Are the injectors spraying? (you can check by pulling a spark plug to check the tip: wet or dry)
Is it getting spark to each cylinder?
Are the plug wires in the correct order?
Old Mar 16, 2011 | 07:31 PM
evandubya's Avatar
Primer Grey FTW!
https://www.zdriver.com/forums/showthread.php?t=32144
Is this the same car as your other thread?
Old Mar 16, 2011 | 08:39 PM
lawlz... good catch.
lemme merge-ify dem threads....
Old Mar 17, 2011 | 08:31 AM
The injectors are spraying. each cylinder is getting spark and the plug wires are in correct order.
-proper air
-proper fuel
-proper spark
Old Mar 17, 2011 | 12:56 PM
Let me make sure I understand you...
The car was running fine, you replaced the cap & rotor, didn't secure it tight, rotor chopped into the cap, replaced the cap & rotor, and now it won't start?
There are only so many things that can be wrong... and I still think the plug wires aren't in the correct order.
Or the CAS was damaged / unplugged.
Or the timing is WAY off.
Old Mar 18, 2011 | 10:40 AM
Or there is a problem with the plug wires. You should also check the ohms across the wires. If you had an electrical issues the wires could be the problem as well.
Old Mar 18, 2011 | 01:12 PM
Plug wires are right. It is running now. but missing. timing is fine. we checked that too once it got running.
Old Mar 18, 2011 | 06:35 PM
How did you get it running?
Old Mar 19, 2011 | 06:20 PM
sorry guys
sorry for the funny stuff my wife had been posting according to my bitching fits about the 280zx i had recently got. the pick up and disc in the dizzy under the metal plate was twisted from my cap and rotor crash lol. i installed a new dizzy and nothing the mech at the shop said it was 180 out and turned my dizzy around with the plug at the rear not the front like it was when i got it. and he said my coil was wired backwards he put them on blue and white on the pos and the black on the neg. it ran then put had very bad miss the tach was going crazy. then after about 10 min of idle it died and would not start at all. no fire from the coil we even hot wired the coil to try and make it fire and nothing happened so i got a accel super coil put it in. still wont start the new coil fires now im not getting signal from my new dizzy im thinking the signal amp on the side off the coil mount? anyway how could it run so good when i got it with the dizzy in the other way and the coil wired wrong i dont know who to belive! help if you can. thanks for all the post now that i got to read them......
Old Apr 6, 2011 | 08:28 PM
Dassan80z's Avatar
Have you checked your fusible links?
Old Apr 7, 2011 | 10:14 AM
zstuff's Avatar
zxt?
whats your furel like and fuel pressure try clamping off return fuel line after inj's next to fuel filter if engine peps up try reving up motor .also I think the cylinder head temp was crytical on that f.i.system next to spark plug #6 firewall good luck.
Old Apr 7, 2011 | 10:17 AM
zstuff's Avatar
zxt
hello isn't the crank angle sensor in a 83zxt distributor?if so you probably damaged the c.a.s.inside cap
Old Apr 7, 2011 | 10:23 AM
^^^ ... Great minds and such ...
Old Apr 7, 2011 | 03:51 PM
i think the coil stopped working becuase they wired it backwards. prolly fried everything else.
