82 280zx Rebuild Progress
Old Sep 19, 2013 | 02:34 PM
  #176
Twiggs280zx's Avatar
Damn Alternator
After taking the Z for a much needed bath I find out the seals between the door glass and T-tops on both sides leak. And the seal on the top of the windshield.
When I got home I pulled the car into the garage and it died a couple min later. I jumped it and pulled the pos off the battery and boom another bad alternator... Good thing summit racing will take it back.
Old Sep 19, 2013 | 03:30 PM
  #177
Friction anyone?
Old Oct 3, 2013 | 07:35 PM
  #178
So I was having an acceleration issue. The motor would idle fine at about 7-800 rpm but sounded a little weak then when raising the rpm to above 2,000 it would bog down then go. It did this both sitting and driving.
I checked the timing and it was +10, I returned it to 0 and it got worse so I tried to return it to +10 and slipped it to +22 and wow it smoothed out at idle and the acceleration was much smoother and more responsive without the bogging.
How bad would it be if I leave it at +22?
Old Oct 4, 2013 | 07:12 AM
  #179
As long as it's not detonating / pinging, you're fine. Just remember to turn it back down come smog check time. Shady280 runs his n/a at about 15*. The L28ET stock timing is 24*.
Old Oct 4, 2013 | 01:24 PM
  #180
Fantastic!
Now I have to open the rocker cover, there's a metal on metal "ticking" sound coming from there. FML
Old Oct 22, 2013 | 04:10 PM
  #181
Its official!
Old Nov 2, 2013 | 03:12 PM
  #182
Exhaust 1/2 White 1/2 Black
Just pulled the exhaust manifold and this is what I see. What is causing this?
Old Nov 2, 2013 | 04:40 PM
  #183
mrprofile's Avatar
It looks fine to me, what do you think is wrong?
oh yea and that metal ticking you're hearing is most likely one of two things, your fuel injectors ticking away, or you need to adjust your valve lash, the FSM has a great section on how to adjust it, and you don't need that special wrench they tell you to use, it can be easily done with two normal wrenches.
Old Nov 2, 2013 | 08:41 PM
  #184
[QUOTE=mrprofile;329247]It looks fine to me, what do you think is wrong?
I thought it would be black in all 6 not white in 3 and black in the other 3.
It is only noticeable after the motor is off, and I've unplugged each injector and it continues.
QUOTE]
Old Nov 3, 2013 | 11:17 AM
  #185
mrprofile's Avatar
oh, the white is probably from burning oil, I came to that conclusion by looking at a plug plug diagnosis chart.
it ticks after the engine is off? and your sure its not just the exhaust ticking like it does in every car?
Old Nov 3, 2013 | 01:01 PM
  #186
I'll have to check the plugs and see why it's burning oil.
Old Jan 23, 2014 | 02:35 PM
  #187
It has been a while since I have been on here. Thanks to EvanDubYa I now have a full exhaust with a magnaflow muffler. Next pain is getting the intake manifold bolted back in. Then some time this spring/summer the suspension should be upgraded to polyurethane.
Old Jan 24, 2014 | 10:15 AM
  #188
evandubya's Avatar
Primer Grey FTW!
That thing is going to sound awesome!!!
Old Feb 6, 2014 | 03:38 PM
  #189
It does sound great! RPD and Highway Patrol don't seem to like it.
Next project is the suspension then the weather stripping.
Old Mar 5, 2014 | 10:26 PM
  #190
Weeeelllllll.... crap. Killed another alternator. WTF is going on here? This is #3 of the GM 1 wire alternators. Could the belt be too tight?
Sadly this happens the same day I find out I got a new job 30 miles away.
Old Mar 6, 2014 | 12:33 AM
  #191
Stukinit's Avatar
Have you checked the timing cover water outlet for drips/pressure spray?
What make/model alternator you using? Getting the crappy autozone remans?
Old Mar 6, 2014 | 11:47 AM
  #192
There are no signs of leaks anywhere.
The alternator is a GM one-wire from Summit Racing.
Old Mar 6, 2014 | 02:12 PM
  #193
Do you have a huge subwoofer sound system, or any other big electrical upgrades?
For 10 years I've been running a 72amp GM 1-wire with a 0 gauge wire straight to the battery... granted, the car has been garaged 90% of that time.
Old Mar 6, 2014 | 03:39 PM
  #194
Everything is stock on this Z. I found the culprit after loosening the alternators adjustable bolt.... The bottom bolt snapped clean off...
Old Mar 6, 2014 | 05:48 PM
  #195
Donn144's Avatar
AmaZing!
Old Mar 6, 2014 | 05:49 PM
  #196
Donn144's Avatar
AmaZing!
I have loved the green 280ZX Always my favorite car..the black and gold was not bad either.
Old Mar 11, 2014 | 05:55 PM
  #197
evandubya's Avatar
Primer Grey FTW!
Did you get it fixed yet?
Old Mar 18, 2014 | 08:53 PM
  #198
Runs like a champ now. But, I managed to break the drivers door window...
Old Jul 1, 2014 | 07:25 PM
  #199
Been driving to and from work for a while now. No major issues thus far. I am going to take the Z to EvanDubYa's in September to get the suspension done. All bushings are getting replaced. We are thinking about doing solid aluminum for the rear sub-frame.
Old Jul 5, 2014 | 04:56 PM
  #200
Anyone had any knocking to the rear of the rocker cover after an oil change?
