81 280zxt w/ z31 ecu maf issues
Old Oct 26, 2014 | 06:36 PM
datsun280zxt's Avatar
Ok i worked on my 81 zxturbo with z31 ecu maf.. when floored it goes to 3-4k and starts poping like Fireworks but if i accel slowly it goes all the way to 5-6k.. when it pops gauge shows rich mixture.. rechecked valve adjustment replaced rotor cap.. it seams like its not getting enough air or spark.. black smokes comes out.. need help
Old Oct 29, 2014 | 01:06 PM
Still haven't found the problem on Jarom's car either...
New MAF, coil, ignitor, and all new EFI wiring. I will be swapping in a VG30E CAS and different turbo injectors this week...
Old Oct 29, 2014 | 11:27 PM
borini63's Avatar
Fuel pump?
Old Nov 6, 2014 | 06:52 AM
This was discussed on FB... not sure if he fixed it yet, but on Jarom's car that I've been working on it was a combination of 3 things:
-Camshaft sprocket was 1 tooth off
-Distributor shaft was 1 tooth off
-Faulty CAS in the distributor
Fixed the timing and replaced the CAS with one from a Z31 and it runs great.
I know datsun280zxt (Guillermo) didn't have the timing mark plate attached to the timing cover, so he couldn't even check the timing. He said he was going to reinstall it.
81turbocoupetx
Dec 19, 2012 02:56 PM
Drunken Crooner
Oct 8, 2012 10:17 AM
ricksilvia
Aug 4, 2012 05:40 PM
nismo619
Nov 10, 2005 10:23 PM
280 drooler
Jul 16, 2003 11:48 AM
