79-83 Recalls
Old Oct 17, 2006 | 09:05 PM
FubarI33t's Avatar
79-83 Recalls
So...... There's a recall out on the S130's
http://www.automotive.com/used-cars/...0zx/index.html
I wounder if they would still fix. hummmm
Old Oct 17, 2006 | 09:24 PM
Z Car Barbie's Avatar
User Friendly
Yeah, the dealership should repair these items due to the recalls if they haven't already been performed. The age of the car does play a role in it though, so it's best to call the dealership and discuss it with the service manager.
Here's the info. I had researched a while back (same info. from Fubar's link above):
1979-1983 280ZX Recall
Auto Recall Date: 07/06/1987
Vehicle Component: POWER TRAIN: AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:FLOOR SHIFT
Estimated Vehicles Affected: 183519
Defect Summary: UNINTENDED ACCELERATION MAY OCCUR, FOR EXAMPLE, WHEN SHIFTING FROM THE PARK POSITION.
Defect Consequence: THIS COULD RESULT IN A VEHICLE ACCIDENT.
Remedy: INSTALL A SHIFT INTERLOCK SYSTEM WHICH PREVENTS THE TRANSMISSION SHIFT LEVER FROM BEING MOVED FROM THE PARK POSITION UNLESS THE BRAKE PEDAL IS DEPRESSED.
Notes: NISSAN NORTH AMERICA, INC.
______________________________
1979 280ZX
Recall Date : NOV 08, 1979
Component: FUEL SYSTEM, GASOLINE:FUEL INJECTION SYSTEM
Potential Number Of Units Affected : 295710
Summary:
MOISTURE AND BLOW OF MIST PRESENT IN THE POSITIVE CRANKCASE VENTILATION SYSTEM MAY, UNDER CONDITIONS OF SUB-ZERO TEMPERATURES, ACCUMULATE IN THE AIR REGULATOR, CAUSING PROLONGED ENGINE IDLE, IF OWNER FAILS TO FULLY WARM ENGINE BEFORE DRIVING. THE PCV SYSTEM CAN ALSO CAUSE A GUMMING IN THE THROTTLE SHAFT WHICH WILL IMPAIR THE SMOOTH OPEN/CLOSE OPERATION OF THE THROTTLE.
Consequence:
Remedy:
DEALER WILL INSPECT AND, IF NECESSARY, INSTALL A NEW PCV VALVE SYSTEM WITH INCREASED FLOW CAPACITY. THE THROTTLE CHAMBERS AND AIR REGULATORS WILL BE INSPECTED AND CORRECTED AND A FINAL SYSTEM INTEGRITY CHECK WILL BE PERFORMED AT NO COST TO OWNER.
Notes:
VEHICLE DESCRIPTION: PASSENGER VEHICLES.SYSTEM: FUEL INJECTION; ELECTRICAL.CONSEQUENCES OF DEFECT: SHOULD HIGH IDLE OCCUR WHEN THE ROADS ARE WET ORCOVERED WITH SNOW AND ICE, HARD BRAKING CAN CAUSE LOSS OF VEHICLE CONTROL AND AVEHICLE ACCIDENT.
NOTE: THE OWNER IS ADVISED TO WARM UP THE ENGINE PROPERLY BEFORE DRIVING THE CAR IN SEVERELY COLD WEATHER.
Old Oct 18, 2006 | 07:09 AM
wreckedj30's Avatar
No Club Love
my gas pedal was sticking the other day, and all i did was regrease, and wd40 it and she was good as new. Also my carpet is high there so i had to cut a 1/2 inch or so off. Yeah thats scary accelerating with out doing any thing.
Old Oct 18, 2006 | 05:40 PM
nismo619's Avatar
i know what there saying about increased acc. in the 82 -83 cars.. my 82 non turbo auto matic.. would rev up when i shifted from park to drive... i never took it in to get fixed becuase i never knew about the recall..
Ares
Mar 5, 2009 12:04 PM
passaphist
Jun 8, 2007 01:14 AM
danielschoenwald
Apr 2, 2003 07:36 AM
Dryz
Oct 21, 2002 11:30 AM
sccwm
Oct 5, 2002 05:00 AM
