79-83 Recalls
79-83 Recalls
So...... There's a recall out on the S130's
http://www.automotive.com/used-cars/...0zx/index.html
I wounder if they would still fix. hummmm
Yeah, the dealership should repair these items due to the recalls if they haven't already been performed. The age of the car does play a role in it though, so it's best to call the dealership and discuss it with the service manager.
Here's the info. I had researched a while back (same info. from Fubar's link above):
1979-1983 280ZX Recall
Auto Recall Date: 07/06/1987
Vehicle Component: POWER TRAIN: AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:FLOOR SHIFT
Estimated Vehicles Affected: 183519
Defect Summary: UNINTENDED ACCELERATION MAY OCCUR, FOR EXAMPLE, WHEN SHIFTING FROM THE PARK POSITION.
Defect Consequence: THIS COULD RESULT IN A VEHICLE ACCIDENT.
Remedy: INSTALL A SHIFT INTERLOCK SYSTEM WHICH PREVENTS THE TRANSMISSION SHIFT LEVER FROM BEING MOVED FROM THE PARK POSITION UNLESS THE BRAKE PEDAL IS DEPRESSED.
Notes: NISSAN NORTH AMERICA, INC.
______________________________
1979 280ZX
Recall Date : NOV 08, 1979
Component: FUEL SYSTEM, GASOLINE:FUEL INJECTION SYSTEM
Potential Number Of Units Affected : 295710
Summary:
MOISTURE AND BLOW OF MIST PRESENT IN THE POSITIVE CRANKCASE VENTILATION SYSTEM MAY, UNDER CONDITIONS OF SUB-ZERO TEMPERATURES, ACCUMULATE IN THE AIR REGULATOR, CAUSING PROLONGED ENGINE IDLE, IF OWNER FAILS TO FULLY WARM ENGINE BEFORE DRIVING. THE PCV SYSTEM CAN ALSO CAUSE A GUMMING IN THE THROTTLE SHAFT WHICH WILL IMPAIR THE SMOOTH OPEN/CLOSE OPERATION OF THE THROTTLE.
Consequence:
Remedy:
DEALER WILL INSPECT AND, IF NECESSARY, INSTALL A NEW PCV VALVE SYSTEM WITH INCREASED FLOW CAPACITY. THE THROTTLE CHAMBERS AND AIR REGULATORS WILL BE INSPECTED AND CORRECTED AND A FINAL SYSTEM INTEGRITY CHECK WILL BE PERFORMED AT NO COST TO OWNER.
Notes:
VEHICLE DESCRIPTION: PASSENGER VEHICLES.SYSTEM: FUEL INJECTION; ELECTRICAL.CONSEQUENCES OF DEFECT: SHOULD HIGH IDLE OCCUR WHEN THE ROADS ARE WET ORCOVERED WITH SNOW AND ICE, HARD BRAKING CAN CAUSE LOSS OF VEHICLE CONTROL AND AVEHICLE ACCIDENT.
NOTE: THE OWNER IS ADVISED TO WARM UP THE ENGINE PROPERLY BEFORE DRIVING THE CAR IN SEVERELY COLD WEATHER.
1979 280ZX
Summary:
Consequence:
Remedy:
Notes:
my gas pedal was sticking the other day, and all i did was regrease, and wd40 it and she was good as new. Also my carpet is high there so i had to cut a 1/2 inch or so off. Yeah thats scary accelerating with out doing any thing.
i know what there saying about increased acc. in the 82 -83 cars.. my 82 non turbo auto matic.. would rev up when i shifted from park to drive... i never took it in to get fixed becuase i never knew about the recall..
