3.1 stroker or TT?
Old Sep 27, 2005 | 10:18 PM
ThermalWake's Avatar
3.1 stroker or TT?
im still trying to figure out wat i want to do to my car once i get my sighning bonus... my friend jeremy, says to make a stroker, i like that idea, but i also like TT... or should i do both, or is that over kill. i really wana make it unique. its a 79 2+2 more of the family car. cuz of the 4 seats, but still, i blow ricers doors off all day long and its stock. but i would b stoked if i could push 400-500 hp outa this L28 leme know guys wat i should go with. same goes for parts
Old Sep 27, 2005 | 10:51 PM
jfairladyz's Avatar
I'd upgrade to an F54 block in either case though. Don't use the block out of the 79 (or any pre 81 for that matter) They are pretty stout but not as strong as the F54. Especially in the case of the stroker. The F54 has extra strength cast into the water passages between the cylinders making it a more rigid block. Boring a cylinder that much over is just asking for trouble so you're going to want the best block to begin with. I'd personally stick with the stock displacement and just get a properly sized single turbo. But thats just me. If I had to choose between one of you two options then I'd go with the TT if I had the resources to make it happen. The 3.1 is best left to an NA motor that's not going to see rediculous power levels. More of a torque booster for a stock or mildly modified engine (IMO). It's been know to stand up though so...
If you're looking to push 400-500 hp out of it I'd stay away from the stroker setup because of the increased risk due to degredation of the cylinders. For your power goals go with a boosted setup. Be it TT or single T. Your call. Depends on how much TIME you want to put into it. You're obviously going to have the money to make it happen. TIME is the factor here as most, if not everything will need to be fabricated. A custom intake and exhaust manifold will NEED to be fabricated with the TT setup. Don't take any of this as discouragment, it's not. Just stuff to take into consideration before you make your choice. And keep in mind, if you don't posses any fabrication skills then that kind of stuff can run you a lot of money for good work. More then what you have to spend. Even at 20G's. So do your research and figure your costs. Then multiply that number by anything bigger then 2. If the final answer is within your budget then go that route. Just put a lot of though and research into this. Don't just rely on what other people tell you what to do. Most have not done either of those options.
Remeber it's not how much money you've got. It's who you know and what you can do yourself. Educate yourself first. Then ask educated questions. Don't throw 20G's into something only to find out you're gonna come up short after you've already spent all your money
Just some words of advice from someone who's been there and done that.
Old Sep 28, 2005 | 08:42 AM
Just do an L28 turbo swap. Single turbo.
Old Sep 28, 2005 | 09:37 AM
s/cL3.0's Avatar
Bleach is my Hero
Yup.. Still get 400-500 HP for less than 6k if you can do most the work yourself..
widebodyz
Aug 3, 2008 08:13 PM
tonsoffun300zx
Apr 17, 2008 06:24 AM
byrneZ
16
Jan 28, 2008 02:04 PM
FubarI33t
Apr 3, 2006 04:22 PM
Adz260
Jun 20, 2003 02:11 PM
