280zx update
Old May 19, 2012 | 03:25 PM
Tsuka89's Avatar
280zx update
Yep, picked up an actual zx-r whale tail for 50$, now I gotta figure out how mount the damn thing, gonna have to fill the rear windshield wiper hole. also bought a 69k turbo parts car front clip for $175, got the engine with above 90% containment on all cyclinders, bumpers, hood vents, interior parts, the entire wiring harness and ecu, the crossmember and rack and pinion system, and some western cyclone II's. AND then I bought a T5 NWC
made some good deals in the last 2 months
swap will happen eventually but I have to go through the engine and replace all the gaskets and the rod bearings-just in case, would like to have a second car before I do the swap and make the zx a dedicated hillclimb/autox car
Old May 19, 2012 | 05:49 PM
mrprofile's Avatar
if you figure out how they did it from the factory you should make a post saying how, i have a zx-r wing too, but i have no idea how to mount it the right way.
Old May 19, 2012 | 06:13 PM
Tsuka89's Avatar
well they used basically an aluminum interior snap pin with a o ring on the underside of the hatch (to prevent leakage-did not work on the ZX-R i got it from) and snapped it through the spoiler and the hatch from the underside of the hatch, if any of that made any sense lol
Old May 19, 2012 | 07:53 PM
Tsuka89's Avatar
well actually riveted on-by the fact that I couldnt get one of the pins out at all
but yeah could be either. best bet is to send it to a body shop and have them put it on, or do it yourself with self tapping screws through the hatch into the spoiler or something -Id seal the spoiler to the hatch though if you can
Old May 24, 2012 | 06:28 PM
Tsuka89's Avatar
heres what Im gonna do to mount, rivet nuts into the spoiler and drill out the hatch, use a circle of silicone or some rubber washers around each hole to seal from the rain. remove the spoiler once every six months or so to clean **** from underneath. profit.
Old May 25, 2012 | 10:41 PM
mrprofile's Avatar
sounds like a good plan, and i think i understood your first way of describing it, it kinda works like hood pins work right?
Old May 26, 2012 | 02:16 PM
Tsuka89's Avatar
um, more like the little plastic snap pins for the hood weatherstripping seals (firewall seal, radiator support seal, front bumper-hood seal)-those pins except in aluminum. wasnt the best way of doing it but whatev
Darkmann
Jul 2, 2008 12:15 AM
n00blar
May 28, 2008 11:13 PM
Seraphic
18
Apr 5, 2005 02:28 PM
ZR8ED
Nov 13, 2003 07:27 AM
gv78280
Oct 5, 2002 09:06 AM
