280zx update
280zx update
Yep, picked up an actual zx-r whale tail for 50$, now I gotta figure out how mount the damn thing, gonna have to fill the rear windshield wiper hole. also bought a 69k turbo parts car front clip for $175, got the engine with above 90% containment on all cyclinders, bumpers, hood vents, interior parts, the entire wiring harness and ecu, the crossmember and rack and pinion system, and some western cyclone II's. AND then I bought a T5 NWC
made some good deals in the last 2 months
swap will happen eventually but I have to go through the engine and replace all the gaskets and the rod bearings-just in case, would like to have a second car before I do the swap and make the zx a dedicated hillclimb/autox car
well they used basically an aluminum interior snap pin with a o ring on the underside of the hatch (to prevent leakage-did not work on the ZX-R i got it from) and snapped it through the spoiler and the hatch from the underside of the hatch, if any of that made any sense lol
well actually riveted on-by the fact that I couldnt get one of the pins out at all
but yeah could be either. best bet is to send it to a body shop and have them put it on, or do it yourself with self tapping screws through the hatch into the spoiler or something -Id seal the spoiler to the hatch though if you can
heres what Im gonna do to mount, rivet nuts into the spoiler and drill out the hatch, use a circle of silicone or some rubber washers around each hole to seal from the rain. remove the spoiler once every six months or so to clean **** from underneath. profit.
um, more like the little plastic snap pins for the hood weatherstripping seals (firewall seal, radiator support seal, front bumper-hood seal)-those pins except in aluminum. wasnt the best way of doing it but whatev
