280zx Stalls while driving
Old Jul 10, 2018 | 09:43 AM
zman62's Avatar
Hi guys,
My z starts and idle well. After driving the car and it warms up, it stalls while driving. When the car is warm, I rev the engine up and let go the pedal, the rpm drops real low that almost makes it stall. So far I replaced the cranckcase water temp, sensor and thermotimer sensor, fuel filter, sparkplugs, but not helping. I hope you guys can help me. Thanks.
Old Jul 10, 2018 | 12:13 PM
Have you read the spark plugs? Checked timing? Checked fuel pressure (running and off)? Ohm checked the CHTS?
Old Jul 12, 2018 | 04:43 AM
zman62's Avatar
What is CHTS? Do you think it is the fuel pressure regulator? I have no idea how to check the timing. I guess I need a timing gun? To be honest, I have very limit skill with cars. I am just trying to fix the simple things.
Old Jul 12, 2018 | 10:17 AM
First thing to do is download the FSM: http://www.xenonzcar.com/s130/fsm.php
CHTS = Cylinder Head Temp Sensor. Located between spark plug 5 & 6 (80.5-83), or in the thermostat housing (pre-80).
Test fuel pressure with a T hooked into the line between the fuel filter and fuel injector rail. Running pressure should be 30-35psi and should not leak down when off.
Yes, checking timing requires a timing light (gun).
Old Jul 13, 2018 | 08:29 AM
zman62's Avatar
Thanks. I will check the fuel pressure. As far as CHTS, I believe that is the crankcase temp sensor which I did replace. It was running rich,rough and black smoke came out the exhaust. It solved the problem after I replaced that.
I was told that may be the ignition module?
Hotrod460
Jul 15, 2018 09:02 PM
mhilldruf1024
Jul 21, 2016 05:07 AM
Dr_Nic_T61
May 29, 2015 10:03 AM
jaromgi
Feb 9, 2012 06:53 AM
jbz32
Sep 8, 2005 02:19 PM
