280zx Low rpm miss
Old Jun 12, 2016 | 08:51 PM
Pickles's Avatar
280zx Low rpm miss
So, I have a 1982 280zx N/A that is completely stock. I bought the car with a half way done clutch job, so unfortuantely, I've never heard how it is supposed to drive. Ever since I've had it, it has had a really bad miss, but it seems to be at low rpms only. The car doesn't have to be on the road, I can simply hit the gas in neutral and make it miss. I have a video of it
I hope it comes through well. The problem goes away if I hit the gas hard enough. (I didn't make a video of this, but I can do that tomorrow if its needed) It has new plugs, wires, and distributor cap. I have also calibrated the AFM with the water test. I also replaced the gaskets for the fuel injectors (completely separate problem that has been solved) I've spent hours, and I mean hours looking for a vacuum leak. I found a couple very small ones, but nothing major. Unless I'm completely missing an area of the engine (which is possible I suppose) then I don't think I have a vacuum leak. I just need some direction. I was thinking maybe the vacuum advance or something? I'm really not sure. I also plan on checking fuel pressure tomorrow. Some direction would be great. If there is anything that I forgot, feel free to ask. Thank you.
Old Jun 15, 2016 | 07:27 AM
Have you checked timing?
Read the spark plugs?
Tested all sensors?
Yes... check fuel pressure too.
Check the basics outlined in the FSM...
Old Jun 19, 2016 | 07:24 PM
Pickles's Avatar
Tested all sensors?
Sorry to be so delayed. I finally figured it out and it turns out the TPS was way off. After adjusting the tps, it runs perfectly fine.
Old Jun 23, 2016 | 10:07 PM
jeffp's Avatar
You really need to fix the exhaust leak. I am hoping it is because you don't have a muffler, if not replace the exhaust manifold gasket pronto. The leaks will make the engine have very poor power and run not so good.
dennys93na300z
May 15, 2014 12:57 PM
dennys93na300z
May 9, 2014 11:23 PM
pauls280
Aug 28, 2005 08:36 AM
FireDhusky
Aug 16, 2004 06:14 AM
pak8899
Oct 7, 2002 05:47 PM
