1983 280ZXT MSD 6AL install?
Old Aug 28, 2012 | 11:19 AM
Darksurf's Avatar
I need help installing the MSD 6AL Ignition Control Box. I need help with the wiring. Also, Do I even need a tach adapter? If I do, which one 8910 or 8920?
I've been researching this for over a week and the best I can find is 240z conversions and non-turbo models. such as this.
MSD 6A Installation with 280zx distributor and 240Z tach
Any help would be much appreciated.
Old Aug 28, 2012 | 04:04 PM
henrycas's Avatar
that will help.
Uploaded with ImageShack.us
Old Oct 28, 2012 | 12:19 AM
ineednewtires's Avatar
Sorry to bump this thread but I've been searching everywhere for anymore useful information.
I am new here and I have tried to "search" as I have in many other forums and nothing specific came through.
As the OP said, there is a 8910, and a 8920, which would I need for a 81 280ZX?
I have it wired in most of the way, just no reading to the tach which I guess is cutting fuel to the car.
Old Oct 28, 2012 | 07:57 PM
The ECU doesn't care if the tach is getting signal or not. The tach signal comes from one side of the coil (blue wire with a bullet connector from the harness inside the inner fender on the driver side IIRC). I'm not sure if you want to hook the 280ZX tach signal to a coil that is getting 400V instead of 12V...
Old Oct 29, 2012 | 10:52 AM
i just used the tach adapter but cant remember what model.
Old Dec 21, 2012 | 03:36 PM
henrycas's Avatar
finally installed my msd box 6200, tach adapter 8210, and SS coil, the car works fine, butt he tachometer does not work.
I understand that the tachometer signal works with original coil negative, and when installing the msd box, the signal for the tachometer and EFI becomes wea. tach adapter supposedly helps the EFI and tachometer work, but in my case the tachometer does not work, I need another type of adapter?
thanks in advance.
masterhufflpuff
Jul 22, 2015 07:05 PM
rhythm
Jan 13, 2013 07:48 PM
Bernardd
Feb 7, 2011 12:04 PM
Adam87
Jun 1, 2010 07:13 AM
DriftZ83
Jan 19, 2008 07:00 PM
