1981 280zx Fan Belt?
Old Aug 11, 2008 | 07:29 PM
chargers21's Avatar
Just started happening, it sounds like the fan belt but I'm not sure. Screeching sound coming from the engine. Does not happen at idle only when pressing gas pedal.
Thanks
Tim in San Diego
Old Aug 11, 2008 | 07:32 PM
SpeciallySpiked's Avatar
I'm a Registered User!
If it's just the typical belt sound, check the tightness of it. It could also be the pulley bearings as that has happened to me before.
Old Aug 11, 2008 | 09:50 PM
Tighten the fan belt X2!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ahhhh w00t w00t!!!!!!
Old Aug 12, 2008 | 10:31 AM
dustin_ra's Avatar
Mine does the same thing but mostly only when the belt is cold. Dosent last long.
Old Aug 12, 2008 | 10:36 AM
I can't remember if it was someone on here or not, but someone once said that you can lightly rub dish soap on your belt if it just won't stop squealing even after tightening it. Tho... if the belt is still squealing at proper tension, something else is probably wrong.
Old Aug 12, 2008 | 10:38 AM
might also want to look at your alt. belt to, as those are usually the culprit for screeching belt problems. (around here anyway.)
Chace
Feb 23, 2023 12:10 PM
chargers21
Nov 20, 2008 07:27 PM
Nissan4Ever_626
May 31, 2008 08:47 PM
rwright
Nov 2, 2004 09:42 AM
tennis280zx
Oct 31, 2004 10:52 AM
