1979 280zx project
Hi, I have a 1979 280zx n/a and want to make it a drift/gymkhana/touga car. What do I need so I could do all three of them? LOL, with out changing parts each time i go racing...
Last edited by NismoPick; Apr 20, 2010 at 10:23 AM. Reason: Grah-merr is guud! SPELL CHECK IS BETTER.
I fixed your question so it's understandable.
Just build your car to race... there's no "set in stone" rules or guidelines. It's your car.
But... some things that will make life easier:
-LSD
-Coilovers
-More hp than your stock 120.
-Lots of $Money$
There ya go. Aside from that, feel free to use our SEARCH feature, as all this has been discussed many times before.
-LSD
-Coilovers
-Lots of $Money$
The Limited Slip rear for these cars is the hard to find or expensive piece. Look up where those are found and how much they are. If you can't find one, don't bother with the rest of your project.
An open diff will get you nowhere in drift
Aside from what's mentioned above, tires will make a huge difference. R compound tires will make your car grip well enough to turn some decent lap times provided the rest of the car is dialed in.
I just noticed you got a S130, 79 is about the lightest for the S130's, but a S30 would be ideal for drifting. Lots of torque! the injection is good for what it is, but I am a strong believer in the much better fuel atomization and sweet power of carbs. but tuning is a must. If carbs even crossed your mind, the 4 screw dome top SU's have a LOT of power potential. but if you got the $$$$ triple Minki's or Webers are ultimate in CARB single cylinder tuning(remember i said carb) Suspension is a HUGE factor in the car, and the breaks are "ok" as long as the suspension is right. 5 lug swap and the Toyota 4 piston calipers, or even the Z31 break swap is great for upgrades with out dropping 8K. Don't get me wrong though, EFI today is the way to go. but a SDS such as MegaSquirt will be a must. If your stuck on N/A power, i think a wideband 02 and triple carbs will give you more bang for the buck then MegaSquirt. For N/A
o **** i did not know that the 1979 280zx was the lghtest of the s130 thanks LOL this is wut i got suspension,sway bars.atrut bar.better tires,cam,new injecters,2 way LSD you think thats good to start out with
well. new injectors i hope you meant stock 180CC injectors(only good for 220HP MAX) if you tune really well. Turbo injectors won't do to well on N/A ECU(as far as I am aware, Nismo prove me wrong) and the 79 did not have as many fancy add on's, lighter yes, but not by much. That cam will help, but yet again, factory ECU ain't programmable, so you won't see much from that expensive cam, These engines(along with most) the power is in the head. Build it right. Moving the injectors Further from the head, will help provide more torque, along with Longer runners. For the cheapest longer and Larger runner intake will be the LD28 intake. Perfect for this. You have to mod for injectors, so it will let you place them further back. Atomization is key for efficient power. Google Chrome has a spell checker built in, gives red lines under the words as you type, right click. select right word, So easy.
If you are still running your stock n/a motor, you're probably planting about 100hp to the ground... which is a far cry from enough to drift, or even make that 2way LSD effective. I doubt you could even swing the rear end out with 100hp.
Most of the 240sx S13's that are crazy strung out for drifting have 300-400hp...
does not matter still a slow *** n/a zx. wont be able to do anything. Please dont call yourself a drifter or a racer...Just cause you watch a movie does not make you an experience driver. Also do us another favor get some damn grammar.
http://www.youtube.com/watch?v=PzC6yU6DhkY
That doesn't mean you are doing it right.
areyoutryingtotellmethatgoodgrammarmakesthingseasi ertounderstand!?3@#
I.E. Nismo 1.5 LSD w/ 45 lb/ft breakaway torque, front camber settings at 1.8 degrees, rear at whatever degrees. Caster settings, how much toe in/out, the exact tires you're using, etc.
You can see the point I'm trying to make, but just making a generic statement will not help you dial in your vehicle. You also need more power. Since you seem to have an aversion to forced induction as stated in your other thread, your only options are stand alone management with a ported head, going back to carbs, or using nitrous. Either way, a turbo would still be the best option no matter how you look at it.
well im sorry about that im not from here and dont know english that well and if you dont get it dont write back !****! i thought datsun drivers were helpful, they all think thare all badass cuz they drive datsuns
i can't agree that you focus on power. For drifting you need good suspension, tires, and LSD.
Personally I think turbos suck for drifting, but I'm an NA guy so that's always going to be my opinion
I'd rather have high RPM and no lag. It's just preference really.
Are you drift racing or doing that gay *** points thing I see in video games? If there are points and judges it's not racing.
I'd rather have high RPM and no lag. It's just preference really.Are you drift racing or doing that gay *** points thing I see in video games? If there are points and judges it's not racing.
hay guies dew u think if we start talking like this hell be nice to us cause i rly h8 it when people dnt liek me................. oh and i just got done watching the fast n furious tokyo DRIFT and i went into a walmart parking lot and did donuts around one of the cart boys and his head exploded from the awesome and then i got arrested by the cops but then i invited them over for a steak dinner and a tootsie pop but then they were like we gotta take you to jail anyway for involuntary AWESOME so i spent time in lompoc with Vin Diesel cause he got jailed for racing but then Paul Walker busted in and saved us both then we went for a midnite cruse with Keichi Tsuchiiya and he taught us that:
COUNTER-STEER IS LATE!
so i countersteered and set a Nurburgring record and blew up civics everywhere
but then Keichi Tsuchiiya turned into a Drift King and slammed us with his 86' and we exploded into a million bits, paving the road for drifters everywhere, but then we sank through the pavement and through the ground and we got used as fossil fuels and I'M IN YO GAS TANK!
I am writing my smart *** comment from your Z's gas tank, and all I can say is: Lay off the throttle.
Rainy days at the track are 15% off, Tell your friends!
Last edited by WanganDevilZ; Apr 24, 2010 at 01:34 PM. Reason: Immuh keep on truckin
im planing out a drift set up for my 280zx too... im thinking of a turbo set up (stock), coilovers (have to make the fronts), sway and strut bars, weld lsd out of a ford puss stang (yes this works), stage 1 or 2 clutch, mild cam, knuckle arms for wider angle, getting a local z guy here in town to make me a custom fuel rail and intake manifold (his 280zx does 9s at the track all day) and another buddy of mine has some itb lookin things that he wants to sell me... well once i finish my build ill let ya know how it goes
weld the LSD? wtf?
cam will do you no good
clutch is a good idea, stage 1 is basically stock though (what I've got) Stage 2 is a way better idea
knuckle arms, I'm assuming shorter ones? yeah that doesn't work without a shitload more mods to the control arms and ****, stock angle is fine for getting sideways.
guys get off his case about needing MOAR POWAR to drift (for instance, AE86 Corollas, like 85whp MAX yet there's people sliding them all over the place, and very well at that.)
