Won't crank 1 out of 100 times.
Old 08-12-2007, 06:53 PM
maxtorque's Avatar
Question Won't crank 1 out of 100 times.
I have a 1981 280zx and recently it will not crank probably once every 3 months. A friend told me it may be a dead spot on the starter and if you rock the car in gear it will typically work. Well he was right, it does crank after moving the car slightly. Is it a started problem or something else?
Thanks, MaxTorque
maxtorque is offline
Old 08-12-2007, 06:58 PM
Goofyz's Avatar
wont crank?
or wont start but still makes starter motor noise?
cuase your flywheel is missing a tooth! (probably 2)
Goofyz is offline
Old 08-12-2007, 07:03 PM
maxtorque's Avatar
Question Won't Crank
Nothing from the starter, just does not turn over. Once I rock the car the starter turns over and the car starts fine. No problem again for another 2 - 3 months.
Old 08-12-2007, 07:08 PM
Goofyz's Avatar
Bent starter Pinion, your car gets lonely and just wants to be held and rocked for a bit, Loose wire on starter motor, If its an automatic perhaps your Neutral/park sensor isn't working.
anyone else have any ideas?
Goofyz is offline
Old 08-12-2007, 07:28 PM
flightforlife07's Avatar
crank sensor?
flightforlife07 is offline
Old 08-13-2007, 07:09 AM
"Nothing" meaning the starter is silent? If the starter is the prob, replace it. Or when it happens, tap on the starter & go.
Originally Posted by flightforlife07
crank sensor?
Crank sensor is only on the turbo model (which he didn't specify which he has).
NismoPick is offline
Old 09-09-2009, 08:13 PM
scorpionp54's Avatar
um my car has almost this same problem. except its every day now. its random on how many times i have to turn the key to start it. got a new starter and seemed to help some but now it just turns on in a fewer amount of key turns.
scorpionp54 is offline
Old 09-09-2009, 08:26 PM
w00t! Two year old thread!
Old 09-09-2009, 08:36 PM
ya well my car just started this problem and i found this one so i figured instead of starting a new one i'll go off this one.
in this case where is the actual inhibitor at im looking through the wire diagram and im finding the relay but not the actual inhibitor.
Old 09-11-2009, 10:41 PM
jtschmitz's Avatar
Mine has done a similar thing. I know of 3 vehicles in my life that have done the same thing. First was an 87 s10 Blazer, that eventually was sold because of the problem. When it happened it stopped working entirely and no amount of try would get it to work. My mothers Olds Intrigue was intermittently doing the same thing. She "fixes" the problem by hitting the battery terminals with a wrench thinking its a loose connection. Replaced the battery and the problem seemed to improve.
My z does the same thing (to be honest i've only started it 4-5 times), but it never takes more than a couple tries to get it to start once it happens. My car clicks from the relay but won't turn over, not sure if this is similar to what your car is doing but I would first look at a loose connection, maybe the terminal. Let me know if you get it figured out.
jtschmitz is offline
Old 09-12-2009, 03:05 AM
This facepalm's for you!
skib's Avatar
if its a new starter, check your connections
skib is offline
Old 09-12-2009, 06:17 AM
User395's Avatar
My starter was doing the same thing. I waited awhile before I replaced it and I think I wore down the flywheel.... So it makes that none catching sound every 1-25ish cranks.
Moral of story = replace before you wear it dizown!
User395 is offline
Old 09-12-2009, 11:49 AM
davidjoe007's Avatar
The starter on the Z car is the easiest I've ever changed...takes less than 20 min.
davidjoe007 is offline
Old 09-12-2009, 12:42 PM
skib's Avatar
ya it literally takes less than 5min to change it for me, 2 bolts and a few wires
skib is offline
Old 09-12-2009, 04:15 PM
w0rld's l0ngest m0t0rswap
thetremendousti's Avatar
ya only took me 2 months
thetremendousti is offline
Old 09-12-2009, 04:51 PM
Haterade by da gallon!
280zx2by2's Avatar
anyone else's starter REALLY fkin loud? kind of embarrassing, but i guess so is driving a 2+2 sports car
280zx2by2 is offline
Old 09-12-2009, 06:42 PM
Blah blah blah... I take it you haven't realized (nor many others) that most Porsches are 2+2 ? I don't think it's embarrassing to drive a Porsche.
Old 09-16-2009, 06:52 PM
so i figured it out, there is something bad in the ignition switch. rewired the starter with a toggle switch and now she starts up first time every time.
WildmaN
07-28-2007 04:17 PM
thxone
02-24-2007 04:00 PM
WolfMan
02-17-2006 01:31 AM
81 Black L28E
06-13-2005 08:32 AM
79bigbore280zx
04-16-2003 11:59 AM
Quick Reply: Won't crank 1 out of 100 times.
