vaccum lines
Old Feb 6, 2005 | 07:11 PM
myxp's Avatar
vaccum lines
any pictures or sites that i can go to see what hose goes where,none of my books show a clear picture.Jim
Old Feb 6, 2005 | 10:10 PM
Skully's Avatar
Bleach...you should take a few pix of this and put it as a STICKY ...its good to know.
Old Feb 7, 2005 | 08:43 AM
Depends on what year engine and where on the engine you want pics of the vaccume lines.
Mine is different around the throttle body since I put the larger throttle on.
Old Feb 7, 2005 | 12:53 PM
DoTheDrew888's Avatar
It wont let me repost this pic but here is a link to the picture of the engine bay on my '83 ZX. https://www.zdriver.com/forum/attach...achmentid=1640
myxp's Avatar
bleachzee i have a 83 l28e non turbo. lines from vaccum pump to the manifold,and 2 hoses coming out of fire wall. basically the hoses from where the battery is located.thank
Old Feb 7, 2005 | 01:03 PM
myxp's Avatar
100 thank yous bleachzee,if i could only see where the 2 hoses coming of the firewall goes. jim
Old Feb 7, 2005 | 02:50 PM
Skully's Avatar
hehehe
ok the ones by your battery are your vaccum control for heat/ac and etc.
i have mine hooked up here...well HAD till i took the engine out :P
Old Feb 7, 2005 | 03:14 PM
I'll take some pics of the all stock '83 engines I have in my "parts" cars. (MY parts!)
they're dirty, but it'll be a good reference for future questions.
Old Feb 7, 2005 | 04:49 PM
apollo's Avatar
Pro Pumpkin Carver
since we're on the topic of vacume lines . . . can anybody tell me what this is? it started making a, i dunno, weak souding rattle or sucking noise internaly and when i disconnect the vacume line leading to it the noise stops, but to my knowledge does not hinder engine performance. what is it and whats it do?
Its located just under the idle adjustment
Old Feb 7, 2005 | 07:38 PM
Oh no! Not the internal combustion inhibitor! Replace the hose so maybe it won't "suck".
Part of that thing is the idle speed screw. Here you can see the '83 one looks slightly different.
Old Feb 7, 2005 | 11:53 PM
apollo's Avatar
Pro Pumpkin Carver
the hose is fine, its the thing at the bottom
Old Feb 10, 2005 | 07:04 PM
apollo's Avatar
Pro Pumpkin Carver
so . . .
the noise maker is the BCDD (Boost Control Deceleration Device) this device is vacuum operated and controls the engine RPM when the clutch is disengaged coming to a stop. It is designed to bring the engine idle down slowly. It is actually part of the emission system. The noise I was hearing is a leak in the unit.
Old Feb 15, 2005 | 12:23 PM
myxp's Avatar
vaccum hoses
sir that picture attachment was a great help,however ineed to know or see a close up picture of 2 small hoses coming through the firewall(by the battery) where do they go, also whitch hoses go to the vaccum tank. once again 100 thank yous for your help. thanks to bleachzee and heatrave. Jim
Old Feb 17, 2005 | 05:45 AM
EZDUZIT's Avatar
East Coast Style
Does anyone have a pic or diagram on which vaccum hoses go where from the canister to the distributer to the Throttle boby. Thanks for any response.
Old Feb 18, 2005 | 12:36 AM
myxp's Avatar
dothedrew great help,but i still need to know where the 2 small hoses coming through the firewall(below battery and a little to front) the picture doesnt show them. any help please, also the where do the hoses from the vaccum tank go?. jim
Old Feb 18, 2005 | 06:42 AM
I believe the lines you are talking about are coolant lines that run along the side of the engine. There is a small metal fitting that sticks off the side of the engine just below the spark plugs near the firewall that they connect to. Are those the lines you are talking about?
Old Feb 19, 2005 | 08:45 PM
myxp's Avatar
no sir they are 2 small rubber hoses next to the metal lines. jim
Old Feb 19, 2005 | 08:54 PM
Skully's Avatar
jim i posted this before in same thread did you see it???
are the two lines coming out connected trough like oval shape plastic type plug??
they go here....
Old Feb 20, 2005 | 08:24 AM
myxp's Avatar
vaccum lines
skully iam sorry for beating this to death but i believe them 2 rubber hoses coming through firewall (they connect to the a/c and heater control panel on the dash) and goes to the vaccum tank (located under the engine night light) which the picture does not show the vaccum tank. jim
Old Feb 20, 2005 | 10:22 AM
Ok, I just looked. I found one line coming out of the passenger side of the firewall. It ran to the vacuum tank and connected to the thing with the yellow cap on it (the connection to the left and slightly lower). I hope that helps.
Old Feb 20, 2005 | 10:28 AM
Skully's Avatar
oh that...ok sorry cant help you there look at a schematic...i never had that stuff hooked up...
Old Feb 20, 2005 | 02:09 PM
myxp's Avatar
amen,amen,amen 100 thank yous skully. jim
Old Feb 20, 2005 | 02:17 PM
myxp's Avatar
amen
thats it,god bless for you taking the time to help me. jim
Old Feb 20, 2005 | 02:40 PM
Carl's Z's Avatar
Originally Posted by apollo
so . . .
I've got mine capped off at both ends, and it makes the car sound good when you shift down at a light. This will stop the rattle as well...
Old Feb 20, 2005 | 04:11 PM
Skully's Avatar
do we need it?
i was gonna remove all the uneccessary crap to clean the engine up...i dont have emmisions here so we dont need stuff like that...
