Turbo AFM
Old May 12, 2003 | 07:22 PM
zpeedracer25's Avatar
Question Turbo AFM
Hey all,
My Air Flow Meter just failed on me at a local autocross. Its stuck wide open and its making my car flood unless I keep my foot to the floor...doh! Is there an easy swap out there that someone has done to a hot wire unit or similar without the big expense of an aftermarket engine management system.
Thanks all,
Old May 12, 2003 | 08:39 PM
Or has anyone taken the time to figure out air flow volume vs. voltage so I can figure out my own conversion to hot wire.
Too bad my FSM doesn't have it posted right there for me
Old May 13, 2003 | 08:59 AM
....hmm, or reach in there and force the flap closed. Then try to prop it just a quarter of the way open. You'll be able to idle ok and flutter the throttle. Probably have ok power under 2500rpm or so. That'll get you to work and back I guess if that's what you want. You can buy them used. I saw a few on zcar.com classifieds. A couple for the turbo were only $60!
Old May 13, 2003 | 10:16 AM
Bleach,
I had to remove it to get it unstuck. It moves freely now, but I'm afraid it'll do it again. I also don't like the slow reaction of the flapper type AFMs and the fact that there is a mechanical piece in there to add to the chances of failure. That and its a pain in the neck to get to on a hot car at an autocross event...doh!
Melspace02
FS: 300ZX (84-89)
Sep 5, 2012 06:28 PM
Spyder Z 15
Aug 20, 2008 12:28 PM
johnsonsz31tt
May 7, 2008 07:27 PM
thunderz
Feb 12, 2006 06:46 PM
teamadidas
Jun 2, 2005 04:41 PM
